Hey
Can somebody please fix this? autodesk cant do anything without breaking something:-)
Thanks!
Solved by denisT.MaxDoctor. Go to Solution.
You can ignore the automatic menu creation... comment out everything related to it and create menus manually.
I don't have that file... You can attach it to the post. I'll take a look.
This is the file that has problems with max's new menu. Thank you very much for your enthusiastic response
just delete lines 2130..2209
all macros you should be able to find in the "GoZ" category
