XYZ Data from Excel giving incorrect coordinates
freedom1k
freedom1k
Hello I have a script that will insert XYZ coordinates with yaw, pitch and roll.
The Script grabs the cell data and inserts a Point at a given Time, then with Animate On,  it transform the point to the cells Data.
2 Issues i'm having with the Script.
1st I have fractions of a seconds increment that is needed. The Time is Multiplied by 30 FPS. the Results is a decimal frame in many cases, so I have it rounding down to the whole frame.   Can you Code Time in Sub-Frame Format, like at Frame 22.75 have a keyframe. (I know I can display Frames:Ticks to scrub the timeline in subframes.) Can that be coded? if so please share.
The other Issue is that my X,Y, Z values are not landing on the exact number that's represented in the excel file, but the rotational values are fine.
For instance Row 7 xyz is returning -600.04, 56.888, 31.24. I'm wondering if Max retains variables in memory, and this causes a shift in the results.
WHy wouldn't the World XYZ values work? I have no shifting in the code.
THe xyz values are multiplied by 12 for Inch unit Scene.
theDummy.pos = [(BPrefixdStrings*12), (CPrefixdStrings*-12), (DPrefixdStrings*-12)]
THe excel and Script is attached. Please share solutions and suggestions.
 -- Start an Excel OLE Object
  -- USE SCENE SET TO INCHES units. Open Listener for reported values.
  x = CreateOLEObject "Excel.Application"
  -- Create a new workbook in the new excel document
  ----x.Workbooks.Add
  x.Workbooks.Open("C:\Motion.xls")
 -- This makes Excel Visible
  --x.visible = true
	  --x.Rows.Count
	  --x.application.Cells("A1").Value
(x.application.Range("A1")).value
theDummy = Point showtrajectory:true --create a helper with trajectory on
	TheDummy.size = 400
counter = 3
while counter < 12 do
--while counter != "undefined" do
	counter = counter as String
	--print counter
--COLUMN A
	cellValueA = (x.Range("A" + counter )).value as String
		OldStringA = "d0"
		NewStringA = ""
		APrefixdStrings = replace cellValueA (findstring cellValueA OldStringA) OldStringA.count NewStringA
--COLUMN B
	cellValueB = (x.Range("B" + counter )).value as String
		OldStringB = "d0"
		NewStringB = ""
		BPrefixdStrings = replace cellValueB (findstring cellValueB OldStringB) OldStringB.count NewStringB
--COLUMN C
	cellValueC = (x.Range("C" + counter )).value as String
		OldStringC = "d0"
		NewStringC = ""
		CPrefixdStrings = replace cellValueC (findstring cellValueC OldStringC) OldStringC.count NewStringC
--COLUMN D
	cellValueD = (x.Range("D" + counter )).value as String
		OldStringD = "d0"
		NewStringD = ""
		DPrefixdStrings = replace cellValueD (findstring cellValueD OldStringD) OldStringD.count NewStringD
--COLUMN E
	cellValueE = (x.Range("E" + counter )).value as String
		OldStringE = "d0"
		NewStringE = ""
		EPrefixdStrings = replace cellValueE (findstring cellValueE OldStringE) OldStringE.count NewStringE
--COLUMN F
	cellValueF = (x.Range("F" + counter )).value as String
		OldStringF = "d0"
		NewStringF = ""
		FPrefixdStrings = replace cellValueF (findstring cellValueF OldStringF) OldStringF.count NewStringF
--COLUMN G
	cellValueG = (x.Range("G" + counter )).value as String
		OldStringG = "d0"
		NewStringG = ""
		GPrefixdStrings = replace cellValueG (findstring cellValueG OldStringG) OldStringG.count NewStringG
	--print APrefixdStrings
	print " -- "
		theTIME = APrefixdStrings as Float
		--theTIME = floor ((theTIME)*30 + 0.5)
		theTIME = floor ((theTIME)* 30)
		print counter
		print theTIME
	print BPrefixdStrings
	print CPrefixdStrings
	print DPrefixdStrings
		BPrefixdStrings = BPrefixdStrings as Float
	CPrefixdStrings = CPrefixdStrings as Float
	DPrefixdStrings = DPrefixdStrings as Float
	EPrefixdStrings = EPrefixdStrings as Float
	FPrefixdStrings = FPrefixdStrings as Float
	GPrefixdStrings = GPrefixdStrings as Float
print EPrefixdStrings
print FPrefixdStrings
print GPrefixdStrings
	with animate on --enable autokey animation context
		at time theTIME  --set the current time for the following expression
				--for Scene set to "inches" units, multiple values by 12.
				theDummy.pos = [(BPrefixdStrings*12), (CPrefixdStrings*-12), (DPrefixdStrings*-12)] --place dummy at 1st coord.
		print theDummy.pos
		at time theTIME
		move theDummy [BPrefixdStrings, CPrefixdStrings, DPrefixdStrings]	--moves dummy subsequent values in excel.
		--Rotates the Dummy just fine
		at time theTIME
			theDummy.rotation.x_rotation = EPrefixdStrings
		at time theTIME
			theDummy.rotation.y_rotation = FPrefixdStrings
		at time theTIME
			theDummy.rotation.z_rotation = GPrefixdStrings
	)--End With
		--print trimValue
	counter = counter as Integer
	counter = counter + 1
)--End while
counter = counter - 1
print "Last Row  " + counter as String
 -- Change the color of A1:B1 to red
--(x.application.Range("A1:B1")).Interior.ColorIndex = 45
  -- Save the spreadsheet
  --x.application.ActiveWorkbook.SaveAs(excelFile)
  -- Close the spreadsheet
  x.application.ActiveWorkbook.Close
  -- quit excel
  x.quit()
  -- Release the OLE Object
  releaseOLEObject x
  -- Release ALL OLE Objects, just incase
  releaseAllOLEObjects()
freedom1k
Actually, I found my errors. I had a second move command that overwrote the 1st, thus driving me crazy. 🙂
Also, this answered my question about subframes. Ticks!!
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/MAXScript-Help/files/...
truckexpert
Thanks for posting. This helped me, too.
Peace,
Dave
System Information:
3DS Max 2023 and 2024
Microsoft Windows 11 Pro
Dell Precision 5820
Intel(R) Core(TM) i9-10920X CPU @ 3.50GHz, 3504 Mhz, 12 Core(s), 24 Logical Processor(s)
Display Adapter: NVIDIA RTX A4000
Adapter RAM (1,048,576) bytes
Installed Physical Memory (RAM) 64.0 GB
Total Physical Memory 63.7 GB
Available Physical Memory 45.6 GB
Total Virtual Memory 81.7 GB
Available Virtual Memory 56.5 GB
Page File Space 18.0 GB
TasKall
Community Visitor
Community Visitor
I am trying the script but I have some issues (I have no experience in max scripting)
1. I do not understand what is the "second move command" and therefore I get the double number of X Y Z values.
2. I cannot make it work for more than 11 rows of excel data
Does anyone have a final script to share?
Thank you in advance
freedom1k
Hello.
You have to modify the script to fit your data. change line where it says <12 to fit the lines of Data Rows in your file.
Change counter = 3 to where your data starts.  so if you have unrelated info above Row 3 in Excel, it will be ignored.
I think you also must not have excel open during run-time.
TasKall
Community Visitor
Community Visitor
Thank you. So i have to write always the exact number of the rows in excel to make it work?
Regarding the correct coordinates values? I understand the unit setup and how to fix it but all the coordinates are doubled (for example if x = 13 in excel, the object in max x value will be 26 (as you mentioned in previous reply " I had a second move command that overwrote the 1st, thus driving me crazy") how can i fix it?
