- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello I have a script that will insert XYZ coordinates with yaw, pitch and roll.
The Script grabs the cell data and inserts a Point at a given Time, then with Animate On, it transform the point to the cells Data.
2 Issues i'm having with the Script.
1st I have fractions of a seconds increment that is needed. The Time is Multiplied by 30 FPS. the Results is a decimal frame in many cases, so I have it rounding down to the whole frame. Can you Code Time in Sub-Frame Format, like at Frame 22.75 have a keyframe. (I know I can display Frames:Ticks to scrub the timeline in subframes.) Can that be coded? if so please share.
The other Issue is that my X,Y, Z values are not landing on the exact number that's represented in the excel file, but the rotational values are fine.
For instance Row 7 xyz is returning -600.04, 56.888, 31.24. I'm wondering if Max retains variables in memory, and this causes a shift in the results.
WHy wouldn't the World XYZ values work? I have no shifting in the code.
THe xyz values are multiplied by 12 for Inch unit Scene.
theDummy.pos = [(BPrefixdStrings*12), (CPrefixdStrings*-12), (DPrefixdStrings*-12)]
THe excel and Script is attached. Please share solutions and suggestions.
-- Start an Excel OLE Object
-- USE SCENE SET TO INCHES units. Open Listener for reported values.
x = CreateOLEObject "Excel.Application"
-- Create a new workbook in the new excel document
----x.Workbooks.Add
x.Workbooks.Open("C:\Motion.xls")
-- This makes Excel Visible
--x.visible = true
--x.Rows.Count
--x.application.Cells("A1").Value
(x.application.Range("A1")).value
theDummy = Point showtrajectory:true --create a helper with trajectory on
TheDummy.size = 400
counter = 3
while counter < 12 do
--while counter != "undefined" do
counter = counter as String
--print counter
--COLUMN A
cellValueA = (x.Range("A" + counter )).value as String
OldStringA = "d0"
NewStringA = ""
APrefixdStrings = replace cellValueA (findstring cellValueA OldStringA) OldStringA.count NewStringA
--COLUMN B
cellValueB = (x.Range("B" + counter )).value as String
OldStringB = "d0"
NewStringB = ""
BPrefixdStrings = replace cellValueB (findstring cellValueB OldStringB) OldStringB.count NewStringB
--COLUMN C
cellValueC = (x.Range("C" + counter )).value as String
OldStringC = "d0"
NewStringC = ""
CPrefixdStrings = replace cellValueC (findstring cellValueC OldStringC) OldStringC.count NewStringC
--COLUMN D
cellValueD = (x.Range("D" + counter )).value as String
OldStringD = "d0"
NewStringD = ""
DPrefixdStrings = replace cellValueD (findstring cellValueD OldStringD) OldStringD.count NewStringD
--COLUMN E
cellValueE = (x.Range("E" + counter )).value as String
OldStringE = "d0"
NewStringE = ""
EPrefixdStrings = replace cellValueE (findstring cellValueE OldStringE) OldStringE.count NewStringE
--COLUMN F
cellValueF = (x.Range("F" + counter )).value as String
OldStringF = "d0"
NewStringF = ""
FPrefixdStrings = replace cellValueF (findstring cellValueF OldStringF) OldStringF.count NewStringF
--COLUMN G
cellValueG = (x.Range("G" + counter )).value as String
OldStringG = "d0"
NewStringG = ""
GPrefixdStrings = replace cellValueG (findstring cellValueG OldStringG) OldStringG.count NewStringG
--print APrefixdStrings
print " -- "
theTIME = APrefixdStrings as Float
--theTIME = floor ((theTIME)*30 + 0.5)
theTIME = floor ((theTIME)* 30)
print counter
print theTIME
print BPrefixdStrings
print CPrefixdStrings
print DPrefixdStrings
BPrefixdStrings = BPrefixdStrings as Float
CPrefixdStrings = CPrefixdStrings as Float
DPrefixdStrings = DPrefixdStrings as Float
EPrefixdStrings = EPrefixdStrings as Float
FPrefixdStrings = FPrefixdStrings as Float
GPrefixdStrings = GPrefixdStrings as Float
print EPrefixdStrings
print FPrefixdStrings
print GPrefixdStrings
with animate on --enable autokey animation context
at time theTIME --set the current time for the following expression
--for Scene set to "inches" units, multiple values by 12.
theDummy.pos = [(BPrefixdStrings*12), (CPrefixdStrings*-12), (DPrefixdStrings*-12)] --place dummy at 1st coord.
print theDummy.pos
at time theTIME
move theDummy [BPrefixdStrings, CPrefixdStrings, DPrefixdStrings] --moves dummy subsequent values in excel.
--Rotates the Dummy just fine
at time theTIME
theDummy.rotation.x_rotation = EPrefixdStrings
at time theTIME
theDummy.rotation.y_rotation = FPrefixdStrings
at time theTIME
theDummy.rotation.z_rotation = GPrefixdStrings
)--End With
--print trimValue
counter = counter as Integer
counter = counter + 1
)--End while
counter = counter - 1
print "Last Row " + counter as String
-- Change the color of A1:B1 to red
--(x.application.Range("A1:B1")).Interior.ColorIndex = 45
-- Save the spreadsheet
--x.application.ActiveWorkbook.SaveAs(excelFile)
-- Close the spreadsheet
x.application.ActiveWorkbook.Close
-- quit excel
x.quit()
-- Release the OLE Object
releaseOLEObject x
-- Release ALL OLE Objects, just incase
releaseAllOLEObjects()
