Obviously, this value is stored in one of the max INI files. But this thing is quite new, and it is difficult to know where it is. I could not find it ...
Old methods (preferences.useLargeVertexDots) overwrite this value to default ...
But If you really want to change it, then you can use UIAccessor ... this way has already been shown many times, for example:
fn toggleDisplayTopologyDependenceWarning =
fn PreferenceCallback =
fn setCheckBoxState hwnd state =
local BN_CLICKED = 0
local BM_SETCHECK = 241
local WM_COMMAND = 273
local parent = UIAccessor.getParentWindow hwnd
local id = UIAccessor.getWindowResourceID hwnd
windows.sendMessage hwnd BM_SETCHECK (if state then 1 else 0) 0
windows.sendMessage parent WM_COMMAND ((bit.shift BN_CLICKED 16) + id) hwnd
ok
hWND = DialogMonitorOPS.GetWindowHandle()
if (UIAccessor.GetWindowText hWND) != "Preference Settings" do return true
bt = windows.getchildhwnd hWND "Display Topology-Dependence Warning"
act = (getIniSetting (getMAXIniFile()) #performance #TopoMessage) as integer
setCheckBoxState bt[1] (act == 0)
UIAccessor.SendMessageID hWND #IDOK
true
DialogMonitorOPS.RegisterNotification PreferenceCallback id:#preferencesConfigure
DialogMonitorOPS.Enabled = true
max file preferences
DialogMonitorOPS.unRegisterNotification id:#preferencesConfigure
DialogMonitorOPS.Enabled = false
toggleDisplayTopologyDependenceWarning()
there are some methods to work with spinner as window :
fn editSpinner hwnd val =
WM_CHAR = 0x0102
VK_RETURN = 0x000D
uiaccessor.setwindowtext hwnd (val as string)
windows.sendMessage hwnd WM_CHAR VK_RETURN 0 -- press ENTER key
fn setSpinnerValue val name: =
hwnd = windows.getchildhwnd #max name
hwnd = uiaccessor.getnextwindow hwnd[1]
hwnd = uiaccessor.getfirstchildwindow hwnd
You may have to switch TABs too ... but there are methods for this. You can search on the CGTalk ...
