Vertex Size in maxscript
slava.lobanov.1990
slava.lobanov.1990
Hi. As i can change Vertex size in Maxscript?
denisT.MaxDoctor
Obviously, this value is stored in one of the max INI files. But this thing is quite new, and it is difficult to know where it is. I could not find it ...
Old methods (preferences.useLargeVertexDots) overwrite this value to default ...
But If you really want to change it, then you can use UIAccessor ... this way has already been shown many times, for example:
fn toggleDisplayTopologyDependenceWarning =
	fn PreferenceCallback =
		fn setCheckBoxState hwnd state =
			local BN_CLICKED = 0
			local BM_SETCHECK = 241
			local WM_COMMAND = 273
			local parent = UIAccessor.getParentWindow hwnd
			local id = UIAccessor.getWindowResourceID hwnd
			windows.sendMessage hwnd BM_SETCHECK (if state then 1 else 0) 0
			windows.sendMessage parent WM_COMMAND ((bit.shift BN_CLICKED 16) + id) hwnd
			ok
		hWND = DialogMonitorOPS.GetWindowHandle()
		if (UIAccessor.GetWindowText hWND) != "Preference Settings"  do return true
		bt = windows.getchildhwnd hWND "Display Topology-Dependence Warning"
		act = (getIniSetting (getMAXIniFile()) #performance #TopoMessage) as integer
		setCheckBoxState bt[1] (act == 0)
		UIAccessor.SendMessageID  hWND #IDOK
		true
	DialogMonitorOPS.RegisterNotification PreferenceCallback id:#preferencesConfigure
	DialogMonitorOPS.Enabled = true
	max file preferences
	DialogMonitorOPS.unRegisterNotification id:#preferencesConfigure
	DialogMonitorOPS.Enabled = false
toggleDisplayTopologyDependenceWarning()
there are some methods to work with spinner as window :
fn editSpinner hwnd val =
	WM_CHAR   = 0x0102
	VK_RETURN = 0x000D
	uiaccessor.setwindowtext hwnd (val as string)
	windows.sendMessage hwnd WM_CHAR VK_RETURN 0 -- press ENTER key
fn setSpinnerValue val name: =
	hwnd = windows.getchildhwnd #max name
	hwnd = uiaccessor.getnextwindow hwnd[1]
	hwnd = uiaccessor.getfirstchildwindow hwnd
You may have to switch TABs too ... but there are methods for this. You can search on the CGTalk ...
slava.lobanov.1990
getINISetting (getMAXIniFile()) "Performance" "VertexDotType"
setINISetting (getMAXIniFile()) "Performance" "VertexDotType" "0" -- can be between 0 and 5, where 0=2 and 5=7
i find only this.
denisT.MaxDoctor
i find only this.
Hmm… what max version is it?
denisT.MaxDoctor
i find only this.
Can't get this to work ... there is such a setting, but I don't see it affecting anything. And I don't see its corresponds to dot size in the Preferences dialog.
klvnk
you'd need to restart max to see the result.
domo.spaji
And that modified .ini will be overwritten by default "Save UI conf. on exit" 😁
And with all these conf. things overdone like in Max, God know what you will see! 😫
