Script to Minimize Maximise All Open Dialog Windows
Message 1 of 16
Hi there,
I am needing a script to toggle minimise and maximise the existing open windows.
Anybody can help me?
Accepted solutions (3)
Replies (15)
Message 2 of 16
miauuuu
3ds Max will be also an open window at the time of execution of the script. Do you want to minize it as well?
Be carefull:
local WM_SYSCOMMAND = 0x112
local SC_MINIMIZE = 0xf020
local SC_MAXIMIZE = 0xf030
local SC_RESTORE = 0xf120
for child in (windows.getChildrenHWND 0) do
windows.sendMessage child[1] WM_SYSCOMMAND SC_MINIMIZE 0
https://miauu-maxscript.com/
Message 3 of 16
denisT.MaxDoctor
Be carefull:
The idea is correct, but perhaps too aggressive ... since this is not only about dialogues. Maybe this it will be better:
	WM_SYSCOMMAND 	= 0x0112
	SC_MINIMIZE 	= 0xF020
	SC_MAXIMIZE 	= 0xF030
	SC_RESTORE 		= 0xF120
	for hwnd in UIAccessor.GetPopupDialogs() do
        UIAccessor.SendMessage hwnd WM_SYSCOMMAND SC_MINIMIZE 0
Message 4 of 16
Thank you very much. I don’t want 3ds max screen to be minimised. Only the dialog windows?
can it be like that?
can it work like a toggle to minimise and maximize?
Message 5 of 16
Thank you very much. Today away from my pc but  Will check this tomorrow and will let you know about results. Is this like a toggle?
Message 6 of 16
This works great!
Would you please help me in 2 more things :
1. Can it be possible to make it work like toggle ? to minimize all open and to maximize all minimised?
2. SME is disregarded when minimising. Is it possible to include that as well?
Thanks in advance.
Message 7 of 16
denisT.MaxDoctor
@Anonymous wrote:
This works great!
Thanks in advance.
SOLVED tag had to go to miauuuu. His answer is more correct than mine. When we want to MINIMIZE or MAXIMIZE a window, we expect a window with WS_MINIMIZEBOX or/and WS_MAXIMIZEBOX styles. In my case, I am giving a POPUP style window list. These windows could be designed for NORMAL placement and they should not be minimized or maximized. So, technically, I was wrong.
We need to modify miauuuu's code and add a check that window has WS_MINIMIZEBOX or/and WS_MAXIMIZEBOX style.
Message 8 of 16
denisT.MaxDoctor
SME is a WS_OVERLAPPED window, this is why it doesn't go in Popup Dialogs list
Message 9 of 16
Thanks for the detailed answer.
Unfortunately I am dumb at scripting so I can't say I understood.
Can you please show me how to modify miauu's script?
Thanks for the greatest help!
Message 10 of 16
denisT.MaxDoctor
macroScript MinMaxDialogs
	category: "DTS"
	buttonText:"MINMAX"
	toolTip:"Minimize/Restore(SHIFT) Dialogs"
	autoUndoEnabled:off
	silentErrors:off
	local
		GWL_STYLE   		= -16,
		WS_MINIMIZEBOX 		= 0x00020000L,
		WS_MAXIMIZEBOX 		= 0x00010000L,
		WS_MINIMIZE        	= 0x20000000L,
		WS_MAXIMIZE       	= 0x01000000L,
		WS_VISIBLE         	= 0x10000000L,
		WS_DISABLED        	= 0x08000000L,
		WS_OVERLAPPEDWINDOW = 0x00CF0000L
	local
		GWL_EXSTYLE         = -20,
		WS_EX_TOOLWINDOW    = 0x00000080L
	local
		WM_SYSCOMMAND		= 0x112,
		SC_MINIMIZE 		= 0xF020,
		SC_MAXIMIZE 		= 0xF030,
		SC_RESTORE			= 0xF120
	local MAXHWND = windows.getMAXHWND()
	local _USER32 =
		src="using System;"
		src += "using System.Runtime.InteropServices;"
		src += "class _user32"
		src += "{"
		src += "	[DllImport(\"User32.DLL\", EntryPoint=\"GetWindowLong\")]"
		src += "	public static extern Int32 GetWindowLong(Int32 hWnd, Int32 index);"
		src += "}"
		csharpProvider = dotnetobject "Microsoft.CSharp.CSharpCodeProvider"
		compilerParams = dotnetobject "System.CodeDom.Compiler.CompilerParameters"
		compilerParams.GenerateInMemory = true
		compilerResults = csharpProvider.CompileAssemblyFromSource compilerParams #(src)
		_user32Assembly = compilerResults.CompiledAssembly
		_user32Assembly.CreateInstance "_user32"
	fn getStyle hwnd = (_USER32.GetWindowLong hwnd GWL_STYLE)
	fn getExStyle hwnd = (_USER32.GetWindowLong hwnd GWL_EXSTYLE)
	fn isVisible hwnd = (bit.and (getstyle hwnd) WS_VISIBLE) != 0
	fn isDialog hwnd = (bit.and (getstyle hwnd) WS_OVERLAPPEDWINDOW) != 0 and (bit.and (getexstyle hwnd) WS_EX_TOOLWINDOW) == 0
	fn isMinimizable hwnd = (bit.and (getstyle hwnd) WS_MINIMIZEBOX) != 0
	fn isMaximizable hwnd = (bit.and (getstyle hwnd) WS_MAXIMIZEBOX) != 0
	fn isMinimized hwnd = (bit.and (getstyle hwnd) WS_MINIMIZE) != 0
	fn isMaximized hwnd = (bit.and (getstyle hwnd) WS_MAXIMIZE) != 0
	fn isNormal hwnd = (bit.and (getstyle hwnd) (WS_MINIMIZE + WS_MAXIMIZE)) == 0
	mapped fn minimizeWindow hwnd = if not isMinimized hwnd do windows.sendmessage hwnd WM_SYSCOMMAND SC_MINIMIZE 0
	mapped fn maximizeWindow hwnd = if not isMaximized hwnd do windows.sendmessage hwnd WM_SYSCOMMAND SC_MAXIMIZE 0
	mapped fn restoreWindow hwnd = if not isNormal hwnd do windows.sendmessage hwnd WM_SYSCOMMAND SC_RESTORE 0
	on execute do
		shift = keyboard.shiftpressed
		hwnds = for w in (windows.getchildrenhwnd 0) where (w[2] == MAXHWND or w[6] == MAXHWND) and isDialog w[1] and isVisible w[1] collect w[1]
		(if shift then restoreWindow else minimizeWindow) hwnds
		--updateToolbarButtons()
this macroscript minimizes and restores MAX dialogs.
with a simple click (or hotkey) it minimizes all visible dialogs, with SHIFT + click (or SHIFT + hotkey) restores the dialogs.
maximizing doesn't make sense for multiple dialogs, so I don't do it for all, but if some dialog has been maximized before, it will be restored to its previuos state.
the script must be saved as an MCR file and placed in one of the MAX macroscripts directories.
Message 11 of 16
Thank you very much.😘😍
This is exactly what I wanted.
It minimizes the windows but I does not restore back with shift click.
I made a toolbar button and that is fine. It restores back with shift-click.
I am using 3ds max 2020.
FYI the open dialogs were sme and transform dialog and vfb.
Is it possible to fix?
Message 12 of 16
denisT.MaxDoctor
what can be fixed? I do not understand what the problem is
Message 13 of 16
denisT.MaxDoctor
Ah... I guess. MAX ignores case for hotkeys.
I changed the code to use SHIFT+ or ALT+ for RESTORE
In case of using a hotkey you have to assign two hokeys to the macro (with and without ALT). For example, CTRL+M and ALT+M (or CTRL+ALT+M).. or any other key but with ALT
	category: "DTS"
	buttonText:"MINMAX"
	autoUndoEnabled:off
	silentErrors:off
	local
		GWL_STYLE   		= -16,
	local
		GWL_EXSTYLE         = -20,
	local
		SC_RESTORE			= 0xF120
	local _USER32 =
		src="using System;"
		src += "{"
		src += "}"
	on execute do
		alt = keyboard.shiftpressed or keyboard.altpressed
		(if alt then restoreWindow else minimizeWindow) hwnds
ALT+ doesn't work for macrobuttons, SHIFT+ doesn't work for hotkeys. This is a built-in limitation
Message 14 of 16
Thank you very much. It is working now.
However working with the right ALT key. (which is better for me as I am left handed and holding the stylus on my left and my right hand is free to type)
And thank you for this info about the shift and the alt key for macros.
I want to get into maxscript.
Do you have any recommendation to start from?
Message 15 of 16
denisT.MaxDoctor
You have to find and run a real project, put the MAXScript help as a Bible on your desktop and nightstand, and make friends on one of the popular 3DS MAX forums (AREA, CGTalk, etc.). This is how it works.
Message 16 of 16
Thanks a lot. I will keep your advice.
