3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
Script to condense material ID
18 REPLIES 18
Message 1 of 19
5007 Views, 18 Replies
Hi all!
I'm a 3D artist (I don't know scripting unfortunetly) and I search a script to condense ID of multi/subobject material which share the same name material.
I found this script via scriptspot:
http://www.scriptspot.com/forums/3ds-max/scripts-wanted/req-material-id-condense-by-part-of-material...
pattern = "*woo*"
mtl = -- your multi-material goes here
mtls = mtl.materialList
mat = undefined
for i=1 to mtls.count where mtls[i] != undefined do (
    if matchPattern mtls[i].name pattern:pattern do (
        if mat == undefined then mat = mtls[i] else (
            if mat != mtls[i] do mtls[i] = mat
but I have a error message:
--Unknow property: "materialList" in undefined
 Someone can help me to make this script work please?
18 REPLIES 18
Message 2 of 19
miauuuu
Select some objects and run the code below. The script will check each of the selected object and if the object have multimaterial applied it will condense the IDs
    selObjsArr = selection as array
    if selObjsArr.count != 0 then
        pattern = "*woo*"
        for o in selObjsArr do
            if classOf (mtl = o.material) == Multimaterial do
                mat = undefined
    else
        messagebox "Empty selection" title:""
https://miauu-maxscript.com/
Message 3 of 19
in reply to: miauuuu
Hi Miauuu,
Thanks for your answer!
I tested it this morning but I have this error message.
Message 4 of 19
miauuuu
Remove lines 1, 3 and 33 and then execute the code. The real code is between line 5 and 31.
Message 5 of 19
Ok miauuu, thanks for your indulgence.
I test it but nothing happen, maybe I forget something ...
This is how I proceed:
- select my mesh
- Open the script
- Run the script
2018-10-26 16_50_36-C__Program Files_Autodesk_3ds Max 2018_scripts_condense_ID_05.ms - MAXScript.png
Message 6 of 19
miauuuu
 The script works using a pattern for the name of the materials that will be condensed. Currently the pattern is "*woo*". Maybe you have to edit it to fit your needs.
Message 7 of 19
I try but when I put the name of my material I have this error message:
Message 8 of 19
miauuuu
You have to replace only this line:
pattern = "*woo*"
with the name of your material. For example
pattern = "*glass*"
so when the script find a submaterials with names that contain word glass it will condense their IDs.
Message 9 of 19
Ok, I retry but I'm sorry, I can't make it work T_T
The name of my multimaterial is:
Material #348600
The name of my material is:
Material__304649
I made few test ...
test_01test_01test_02test_02test_03test_03
Message 10 of 19
miauuuu
Use the code that I post. I
You use the code incorrectly. The mtl variable is set incorrectly.
Try this:
[code]
        pattern = "*Material__304649*"
                mat = undefined
    else
[/code]
As you can see in my code the mtl varibale holds the material of the object:
mtl = o.material
Message 11 of 19
Sorry, nothing happen ...
Message 12 of 19
miauuuu
The name of your material is Material__304649, but what are the naems of submaterials?
The script check the names of the sumbaterials, not the name of the "main multiSubobject" material. So, for example you have an object with name object_01 and with applied Multimaterial with name Material__304649. It have 5 submaterials with names:
glass_01
wood_03
glass02
stone
in_glass
If you want all submaterials that contains "glass" in its names to be condensed select the object_01 and run this:
        pattern = "*glass*"
                mat = undefined
    else
The script should condense those materials:
glass_01, glass02 and in_glass
becaue all of them have "glass" in their names.
Message 13 of 19
Sorry I'm probably poorly expressed but this is a picture of what I want to do (in a multi/subobject material)
ID.pngThis is not possible?
Message 14 of 19
miauuuu
Maybe it is better to uplad this material so we can download it use it to modify the script.
Message 15 of 19
How Can I share a fbx in this forums?
Message 16 of 19
miauuuu
A link to gdrive, dropbox, etc.
Message 17 of 19
I test with wetransfer:
https://we.tl/t-bW7sIflPPN
Message 18 of 19
miauuuu
Try this:
global CondenseMaterialIDs
try(destroyDialog CondenseMaterialIDs)catch()
rollout CondenseMaterialIDs "Condense Material IDs"
	local collapseBy = "Name"
	local poSetFaceMatID = polyOp.setFaceMatID
	radioButtons CollapseByRadioButtons "Collapse By:" labels:#("Name", "Diffuse Texture Name") default:1
	on CollapseByRadioButtons changed state do
		collapseBy = case CollapseByRadioButtons.state of
			1: "Name"
			2: "TextureName"
			default: "Name"
	fn getTextureName mat =
		local textureName = mat.name
		try
			diffuseTextureMap = mat.diffusemap
-- 			print (classof diffuseTextureMap)
			if classof diffuseTextureMap == Bitmaptexture do
				textureName = getFileNameFile diffuseTextureMap.bitmap.filename
		catch()
		textureName
	button CondenseMaterialIDsButton "Condense Material IDs"
	on CondenseMaterialIDsButton pressed do
		setWaitCursor()
		sel = selection as array
		for obj in sel where classof obj == Editable_Poly  and obj.material != undefined and classof obj.material == MultiMaterial do
-- 			for originalMaterial in obj.material.materialList do
-- 				print (getTextureName originalMaterial)
			materialIDList = obj.material.materialIDList
			materialMap = #()
			append materialMap (findItem materialIDList 1)
			materialList = #(obj.material.materialList[materialMap[1]])
			for i = 2 to materialIDList.count do
				index = (findItem materialIDList i)
				mat = obj.material.materialList[index]
				notFound = true
				newIndex = 0
				for j = 1 to materialList.count while notFound do
					otherMat = materialList[j]
					if collapseBy == "Name" then
						if mat.name == otherMat.name do
							notFound = false
					else
						if collapseBy == "TextureName" do
							if (getTextureName mat) == (getTextureName otherMat) do
								notFound = false
					if not notFound do
						newIndex = j
				if notFound do
					append materialList mat
					newIndex = materialList.count
				append materialMap newIndex;
			if materialList.count != obj.material.materialList.count do
				newMat = MultiMaterial numSubs:materialList.count
				materialFaces = #()
				for i = 1 to newMat.materialList.count do
					newMat.materialList[i] = materialList[i]
					newMat.materialIDList[i] = i
					newMat.names[i] = materialList[i].name
					append materialFaces #()
				obj.material = newMat
				for i = 1 to obj.GetNumFaces() do
					oldMaterialID = obj.GetFaceMaterial i
					oldMaterialIndex = findItem materialIDList oldMaterialID
					newMaterialID = materialMap[oldMaterialIndex]
					if oldMaterialID != newMaterialID do
						append materialFaces[newMaterialID] i
				for i = 1 to materialFaces.count where materialFaces[i].count > 0 do
					poSetFaceMatID obj materialFaces[i] i
		setArrowCursor()
createDialog CondenseMaterialIDs
The original script is here: http://www.scriptspot.com/3ds-max/scripts/material-id-condense
I have made some little modification and now it is run as standard rollout, not as utility.
Works only with editable poly objects, so you have to convert your objects to editable poly.
The object you have uploaded starts with 120 sub-materials. After the script is used only 40 sub-materials remains.
Message 19 of 19
Hi  miauuuu!
IT WORKS! Thanks you so much for your time!
It's a Monday that starts well 😉
