Script save in batch as jpg file
laura.soen
laura.soen
I have a scene with many objects (500+) all in a certain viewpoint.
I want to select all objects in the view they are and save them out individually as separate JPEG files.
It will take too long to go to Render>Save Selected as JPEG file for all of them. Does anyone have a script to save all my objects in separate JPEG files?
Thank you!
denisT.MaxDoctor
fn renderViewNodes nodes:selection =
	local render_path = getdir #temp + @"/scene_render/"
	makedir render_path all:on
	sel_nodes = nodes as array
	vis_nodes = for node in objects where not node.ishidden collect node
	hide objects
	images = for node in sel_nodes collect
		unhide node
		select node
		max tool zoomextents
		filename = node.name + ".jpg"
		filepath = render_path + filename
		render outputfile:filepath vfb:off
		hide node
		filepath
	unhide sel_nodes
	select sel_nodes
	hide objects
	unhide vis_nodes
	images
renderViewNodes()
you must make all the rendering settings yourself before the batch, as well as specify your path in the code if you need it...
the batch render script will render all selected nodes from the current active view.
Feel free to ask questions
laura.soen
Hi thanks for the script, but when I try to run it, it does not do anything. I'm new at this, am I doing something wrong?
denisT.MaxDoctor
1. create and select objects you want to render
2. set render settings
3. make the view you want to render from active
4. run the scripts...
5. run in the listener
renderViewNodes()
after that in the "...\temp\scene_render\" you should see newly created *.jpg files - one per node
laura.soen
Hi, I did exactly as you said but the script does not do anything. There is no "temp\scene_render" created in my directory. Is it possible there has to be changed something at the script? I tried scripts before, and they all did work so I have no idea how I can fix this problem. Just to be clear, I added an image of how my scene looks like and how I want it to be rendered as a jpg file one by one. Capture.PNGCapture2.PNG
denisT.MaxDoctor
run :
this is the exact path where jpg images should be stored
in my machine it's:
"C:\Users\<my_machine_name>\AppData\Local\Autodesk\3dsMax\2020 - 64bit\ENU\temp/scene_render/"
denisT.MaxDoctor
run this code and follow common sense:
try(destroydialog RenderPicsRol) catch()
rollout RenderPicsRol "Render pics with denisT" width:191
	fn renderViewNodes nodes:selection dir: callback: =
		if dir == unsupplied do dir = getdir #temp + @"/scene_render/"
		if not doesDirectoryExist dir do
			makedir dir all:on
		dir += @"\\"
		hide objects
		index = 0
		images = for node in sel_nodes while not keyboard.escpressed collect
			unhide node
			select node
			filepath = dir + filename
			index += 1
			if callback != unsupplied do
				callback index filepath
			hide node
			filepath
		unhide sel_nodes
		select sel_nodes
		hide objects
		unhide vis_nodes
		images
	radiobuttons nodes_rb "Nodes:" labels:#("All", "Selected") default:2 columns:2 align:#left offset:[0,4] offsets:#([50,-16],[15,-16])
	button render_pics_bt "Render Pics..." width:172 align:#center offset:[0,6]
	label emp
	label info_line0_lb align:#left across:3
	label info_line1_lb align:#center
	label info_line2_lb align:#right
	fn callback index file =
		info_line0_lb.text = index as string
		info_line1_lb.text = filenamefrompath file
		windows.processPostedMessages()
	on render_pics_bt pressed do
		if (nodes = if nodes_rb.state == 1 then objects else selection as array).count > 0 do
			dir = getSavePath()
			if dir != undefined do
				info_line2_lb.text = nodes.count as string
				renderViewNodes nodes:nodes dir:dir callback:callback
	on RenderPicsRol open do
createdialog RenderPicsRol
