3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
Rename sellected material with maxScript
4 REPLIES 4
peterv42
2289 Views, 4 Replies
I am new to maxScript. I am looking for a script that will rename only my selected material.
Samethink like this:
macroScript RenameThem category: "HowTo"
 rollout rename_rollout "Enter New Base Name"
  edittext base_name ""
  button rename_them "RENAME SELECTED OBJECTS..."
  on rename_them pressed do
   if base_name.text != "" do
    for i in selection do i.name = uniquename base_name.text
  )--end on
 )--end rollout
createDialog rename_rollout 250 50
But this only works on an object.
This works for all my material:
for mat in scenematerials do
    print ("material name: " + mat.name)
	mat.name = "_512_opaque"
So i need only the selection from the scenematerials array.
Hope sameone can help
Greetings Peter
Labels (1)
4 REPLIES 4
denisT.MaxDoctor
in reply to: peterv42
fn collectMaterials nodes =
	/* collect all valid materials that used with the specified list of nodes */
	mats = for node in nodes where node.material != undefined collect node.material
	/* make the list of materials unique to avoid re-naming the same materials */
	makeuniquearray mats
/* mapped functions work for a single input and a "collectable" input argument */
mapped fn renameMaterial mat prefix: postfix: =
	if iskindof prefix String do mat.name = prefix + mat.name
	if iskindof postfix String do mat.name = mat.name + postfix
	ok
-- using:
mats = collectMaterials selection
renameMaterial mats postfix:"_512_opaque"
see MXS help for more information .. or ask questions here if you have
peterv42
in reply to: denisT.MaxDoctor
Thank for your script and explanation. I wanted to select the materials in the slate material editor but this also works.
The postfix and prefix is really nice and understandable but i needed to clear the naming field and only put my naming there but i fixed that.
Thank you,
Greetings Peter
denisT.MaxDoctor
fn sme_getSelectedMaterials view: =
	if view == unsupplied do view = sme.getview sme.activeview
	tv = trackviewnodes[#sme]
	vsub = tv[view.name]
	for k=1 to vsub.numsubs collect
		sub = vsub[k]
		ref = sub.reference
		node = view.getnodebyref ref
		if node.selected and iskindof ref Material then ref else dontcollect
mapped fn renameMaterial mat name: prefix: postfix: =
	name = if iskindof name String then name else mat.name
	if iskindof prefix String do name = prefix + name
	if iskindof postfix String do name = name + postfix
	mat.name = name
	ok
mats = sme_getSelectedMaterials()
I added how to get selected materials from SME, and modified rename material function to be able to set new name as well.
peterv42
Hello DennisT,
This script is even better it is doing exacly what i had in mind.
I included a last line:
renameMaterial mats name:"naam_opaque"
This realy help in automating my workflow.
Greetings Peter
Technology Administrators
