randomly select edge or edges on Object
admin
Message 1 of 11
admin
i want to select on or more edges on a selected object
if i use
$.EditablePoly.SetSelection random 1
it runs  my script but errors out with unable to convert random() into Integer
Can someone post me a help o to this up
fn edgSlct obj=
   i select my object
   i turn on subobejctlevel 2
   here i want to pick  a random edge on my selection
Replies (10)
Message 2 of 11
miauuuu
	fn EdgSlct obj =
		if classOf obj == Editable_Poly do
			select obj
			max modify mode
			subobjectlevel = 2
			polyop.setEdgeSelection obj (random 1 (polyop.getNumEdges obj))
	EdgSlct selection[1]
https://miauu-maxscript.com/
Message 3 of 11
admin
i figured i need to get the selection somehow and found the get stuff in the documentation but never got it to work. Thank you a lot bro
Message 4 of 11
admin
if i evaluate the script it works and selects a random edge but if i want to use a button to change the selection randomly it sends an error.
1) what did i miss here???
2) where is the amount of selcted edges done? When i set random to 3 it selects still one edge....??
What does EdgSlct selection[1] exactly???
See Screenshot
Message 5 of 11
miauuuu
	global rol_testingStuff
	try(destroyDialog rol_testingStuff)catch()
	rollout rol_testingStuff "WHOPPER"
		spinner spn_edgesToSel "Edges to select:" range:[1,1000,3] width:80 type:#integer
		button btn_test "WHOPPER"
		fn EdgSlct obj =
				select obj
				max modify mode
				subobjectlevel = 2
				spnVal = spn_edgesToSel.value
				edgCnt = polyop.getNumEdges obj
				case of
					(spnVal > edgCnt): messagebox "Selected object has less edges than the value in the spinner"
					(spnVal == edgCnt): (polyop.setEdgeSelection obj #{1..edgCnt})
					default:
						edgToSelBA = #{}
						while edgToSelBA.numberset < spnVal do
							edgToSelBA  += #{(random 1 edgCnt)}
						polyop.setEdgeSelection obj edgToSelBA
		on btn_test pressed do
			if selection.count == 1 do
	createdialog rol_testingStuff width:200
Message 6 of 11
denisT.MaxDoctor
You didn't read my posts carefully..... 😉
Use #shuffle!
Message 7 of 11
denisT.MaxDoctor
with #while you might go into an infinite loop.  not quite infinite, but it can be very, very long. 🙂
Message 8 of 11
miauuuu
Yes, I know. 🙂
If the user decide to select 900 of 1000 edges it is better to generate 100 random numbers and then to use the rest of the numbers instead of waiting 3dsMax to generate 900 random numbers.
This shuffles the array, but on my Max2020, despite the edgToSelArr is filled with correct amount of numbers, 3dsMax selects equal or less amount of edges. 🙂
		fn ShuffleArr arr =
			for i = arr.count to 1 by -1 collect
				swapIndex = random 1 i
				swap arr[random 1 i] arr[i]
		fn EdgSlct obj =
				select obj
				max modify mode
				subobjectlevel = 2
				case of
					default:
						randomizedArr = ShuffleArr (#{1..edgCnt} as array)
						edgToSelArr = for i = 1 to spnVal collect randomizedArr[i]
						polyop.setEdgeSelection obj edgToSelArr
Message 9 of 11
denisT.MaxDoctor
your shuffle function seems not correct... here is what I do:
fn shuffleArray list =
	for k = 1 to list.count do
		i = random 1 k
		swap list[k] list[i]
	list
fn selectPolyRandomVerts node numv seedvalue: =
	if seedvalue != unsupplied do seed seedvalue
	list = shuffleArray ((node.verts as bitarray) as array)
	list.count = amin numv list.count
	node.selectedverts = list
delete objects
gc()
t = converttopoly (teapot segments:100 isselected:on)
selectPolyRandomVerts t 100000)
Message 10 of 11
denisT.MaxDoctor
But of course, there is no need to shuffle all verts if you need a part. This will be a homework on how to modify the shuffle method to shuffle only the needed number 😉
Message 11 of 11
denisT.MaxDoctor
but these are outdated methods... now you can use Python 😊
