Announcements
Creating Rollout Panel like in the cmd panel
admin
admin
Hey Pros,
i searched inside the Script Hellp and in the Internet but i do not find anything how to script a rollout with panels like the command pannel has.
I kust found some rollout floater stuff (which is helping too in organising things) BUT how is a rollout/UI sgement with panels done? it does not need to have UI Icons i just want to see some code example or link where i can get into this.
Reason: i am thinking about a tool in max i eant to do which needs to be organized in a similar kind of fashion like we have in the commad thingy.
Can this be done in Max Script or do i need to look somewhere else for it?
Where can i find a very basic example how the panels are done?
denisT.MaxDoctor
This is RolloutFloater. You can find many examples. There is some in the MaxScript Help.
miauuuu
Maybe what you need is the dotNet "TabControl", so you can have tabs like Command, Modify, etc. which will show the UI you need.
https://miauu-maxscript.com/
w.haak
You can use a rollout floater to be able to have collapsible sections:
Rollout TheRollout "1st rollout"
--- Create Floater---
try (closeRolloutFloater theNewFloater)catch()
theNewFloater = newRolloutFloater "Floater Name" 300 500
--- Add default Rollouts---
Addrollout TheRollout theNewFloater rolledUp:false
  with
removeRollout TheRollout
you can turn sections on and off. I use this with a radiobutton in the first rollout, which then uses removeRollout  and AddRollout to close, open and re-order sections as needed.
