Announcements
Changing Caption on a Button in Script during Flow
admin
admin
Hey folks.
I have a button "MyButtonName" pos....etc
I want to change the Button Caption on different actions like this:
1. Button Caption is: "Select xy"
2. after action is done Button Caption is "DONE"
This is already Working!
Now i want to set it back to the Start means after a short sleep i want to have it back to Caption in 1 ("select xy")
In Unity i did such things with switch cases but in Maxscript i am lost.
How can i set a kind of procedural Caption Placeholder that carries out the Caption name into the button?
THX and Regards
denisT.MaxDoctor
what button do you talk about? Rollout button? Macro button? ...
denisT.MaxDoctor
for Rollout UI controls the most common solution is to use a Timer control:
try(destroydialog rol) catch ()
rollout rol "RO:3DE86D88" width:191
	timer job_tm interval:2000 active:off
	button select_bt "Select" width:160
	checkbutton process_bt "Process" highlightcolor:brown width:160 offset:[0,8]
	local recent_job = undefined
	on job_tm tick do
		if recent_job != undefined do recent_job()
		job_tm.active = off
	on select_bt pressed do
		select_bt.text = "DONE"
		recent_job = (fn _ = (select_bt.text = "Select"))
		job_tm.active = on
	on process_bt changed state do
		if state then
			process_bt.text = "Processing..."
			recent_job = (fn _ = (process_bt.changed off))
		else
			job_tm.active = off
			process_bt.state = off
			process_bt.text = "Process"
		job_tm.active = on
	on rol open do
createdialog rol
denisT.MaxDoctor
another solution is to use scene notifications and node events... that's another story
admin
Hey Pros, @denisT.MaxDoctor
i set up a small example to train myself with this noob logic
see attached script example
 this is just for learning purposes, it might be a dumb approach but
 let me just solve it to understand the tracking in this case of a simple string value!
I tried the fn inside and outisde the rollout but i cant keep track of the string/caption value
 try (closeRolloutFloater theNewFloater) catch()
btnTxt = "Default Name"
MyState = 1
 rollout ButtonTest1 "Grin Control"
   --fn changeMe1=
--btnTxt = "New Name"
button 'btn6' btnTxt pos:[10,20] width:100 height:50 enabled:true align:#center
   on button pressed do
   --keeo track of the state i am in
   --set the name in a sep function and use the function in
   --the desired state i am in
   MyState.count == 1
   if MyState.count== 1 then ChangeMe1() else
   if MyState.count== then CHangme2() else
   if MyState.count == 3 do changeMe3()
rollout ButtonTest2 "Grin Control"
   -fn changeMe1=
btnTxt = "New Name"
fn changeMe1=
btnTxt = "New Name2"
fn changeMe1=
btnTxt = "New Name3"
   theNewFloater = newRolloutFloater "Grinning" 300 220
   addRollout ButtonTest1 theNewFloater
   addRollout ButtonTest2 theNewFloater
