PySide2 widget to drag and drop materials?
inquestudios
Message 1 of 42
inquestudios
I'm trying to develop a simple tool that allows loading and saving of material libraries
AND also drag and drop materials from my widget to material editor and reverse.
What QMimeData type should I set to drop INTO material editor?
I have set def dropEvent to accept all drops right now, it even triggers when I drop data from external application like files from windows explorer. But when I try to drag from material editor slot, it only activates over material slots and viewport objects. How can I force my widget to accept material drops?
Replies (41)
Message 2 of 42
inquestudios
Simplified code:
import pymxs, PySide2
from PySide2.QtWidgets import QHBoxLayout, QWidget, QPushButton
from PySide2.QtCore import Qt, QMimeData
from PySide2.QtGui import QDrag
rt = pymxs.runtime
rt.clearListener()
materialArr = []
maxWindow = QWidget.find(rt.windows.getMaxHWnd())
libFileName = rt.getOpenFileName(caption = "Select library to load", types = "Material library(*.mat)|*.mat")
if libFileName != None:
    clib = rt.loadTempMaterialLibrary(libFileName)
    for i in clib:
        materialArr.append(i)
class DragButton(QPushButton):
    def mouseMoveEvent(self, e):
        if e.buttons() == Qt.LeftButton:
            drag = QDrag(self)
            mime = QMimeData()
            mime.setUrls([])
            drag.setMimeData(mime)
            drag.exec_(Qt.MoveAction)
class tWindow(PySide2.QtWidgets.QMainWindow):
    def __init__(self, parent = maxWindow):
        super(tWindow, self).__init__(parent)
        self.setWindowTitle('Drag test')
        self.setMouseTracking(True)
        self.setAcceptDrops(True)
        self.blayout = QHBoxLayout()
        for l in materialArr:
            btn = DragButton(l.name)
            #btn = QPushButton(l)
            self.blayout.addWidget(btn)
        mw = QWidget()
        self.setCentralWidget(mw)
        mw.setLayout(self.blayout)
    def dragEnterEvent(self, e):
        e.accept()
    def dropEvent(self, e):
        pos = e.pos()
        widget = e.source()
        print(e.pos())
        e.accept()
tw = tWindow()
tw.show()
Message 3 of 42
denisT.MaxDoctor
The simple answer is, "You can't."
MAX has and uses its own Drag-n-Drop (DAD) mechanism that has nothing to do with Qt, .NET, or Win
But there is a complicated way to do it... and it's the only one I see as possible unless you use c++ MAX and Qt SDKs...
The hard way is to add a MAX Rollout control (specifically MaterialButton) to the Qt widget. After that MAX DAD should work as an embedded one
Message 4 of 42
inquestudios
Another question then - can I embed MAXscript rollout into QT window as layout, or something like that?
Message 5 of 42
denisT.MaxDoctor
The answer is obvious... of course, you can... Almost the entire MAX user interface is made this way now. 😁
Message 6 of 42
inquestudios
Very well, could you supply any example? How can I put simple rollout
rollout mbtest "Matbuttons"
	materialButton mb1 "Test" width:100 height:100
into
rt = pymxs.runtime
mxsstr = 'rollout mbtest "Matbuttons"\n(\n\tmaterialButton mb1 "Test" width:100 height:100\n)'
rt.execute(mxsstr)
maxWindow = PySide2.QtWidgets.QWidget.find(rt.windows.getMaxHWnd())
class CBrowser(PySide2.QtWidgets.QMainWindow):
        super(CBrowser, self).__init__(parent)
        self.setCentralWidget(???)
        self.resize(850, 600)
cWindow = CBrowser()
cWindow.show()
Message 7 of 42
denisT.MaxDoctor
If I told you everything, it wouldn't be interesting!
Besides, Swordslayer and I have already shown how to do it, maybe not on this forum, but on some other forum.
But I'll give you a hint:
createdialog mbtest
cui.RegisterDialogBar mbtest
The only thing left to do is to change the Qt parent... 😎
Message 8 of 42
denisT.MaxDoctor
By the way what MAX version do you use?
Message 9 of 42
inquestudios
I'm developing my tool for 2019 and later.
So, looks like after cui.RegisterDialogBar rollout becomes a child widget for main 3ds MAX window.
That's the game changer, thank you for the good lead.
rt = pymxs.runtime
rt.clearListener()
mxsstr = 'rollout mbtest "Matbuttons"\n(\n\tmaterialButton mb1 "Test" width:100 height:100\n)\ncreatedialog mbtest\ncui.RegisterDialogBar mbtest'
rt.execute(mxsstr)
def procCh(wd):
    chArr = wd.children()
    for cch in chArr:
        if type(cch) == PySide2.QtWidgets.QDockWidget:
            if cch.windowTitle() == 'Matbuttons':
                print(cch)
procCh(maxWindow)
Message 10 of 42
inquestudios
Ok, I've managed to find and reparent widget with materialbuttons!
rt = pymxs.runtime
rt.clearListener()
mxsstr = 'rollout mbtest "Matbuttons"\n(\n\tmaterialButton mb1 "Test1" width:100 height:100 across:3\n\tmaterialButton mb2 "Test2" width:100 height:100\n\tmaterialButton mb3 "Test3" width:100 height:100\n)\ncreatedialog mbtest width:450\ncui.RegisterDialogBar mbtest'
#print(mxsstr)
rt.execute(mxsstr)
def procCh(wd):
    for cch in chArr:
                return cch
rw = procCh(maxWindow)
stuctArr = rw.children()
        self.setCentralWidget(stuctArr[5])
cWindow.show()
print(cWindow.centralWidget())
The bad news - I can't find the way to access elements inside the widget.
children() returns some useless QPropertyAnimation
layout() returns None
How can I address individual buttons?
Message 11 of 42
denisT.MaxDoctor
by HWHD
Message 12 of 42
inquestudios
I have collected
<rollout>.controls[<index>].hwnd
ran
PySide2.QtWidgets.QWidget.find()
with this parameter and got None
What am I doing wrong?
Should I get winId from reparented widget and offset from there?
Message 13 of 42
denisT.MaxDoctor
The hwnd of the Rollout control is an array... because a control can consist of multiple windows. For example, a spinner has a body control and a caption control... and so on. In short, you usually use the first hwnd in the array.
Message 14 of 42
denisT.MaxDoctor
Is it some kind of challenge to make a tool in Python?
That's fine. But the implementation of Python in versions 2019 and 2025 is very different. You will have problems supporting all these versions with more or less the same code.
Message 15 of 42
inquestudios
Here's the code:
rt = pymxs.runtime
rt.clearListener()
mxsstr = 'rollout mbtest "Matbuttons"\n(\n\tmaterialButton mb1 "Test1" width:100 height:100 across:3\n\tmaterialButton mb2 "Test2" width:100 height:100\n\tmaterialButton mb3 "Test3" width:100 height:100\n)\ncreatedialog mbtest width:450\ncui.RegisterDialogBar mbtest\n'
print(mxsstr)
rt.execute(mxsstr)
def procCh(wd):
    for cch in chArr:
                return cch
for i in rt.mbtest.controls:
    chwnd = i.hwnd[0]
    print(PySide2.QtWidgets.QWidget.find(chwnd))
cWindow.show()
And the output:
None
None
None
I'm getting hwnd for every control, but QWidget.find(<hwnd>) returns None
Let's assume I am working with 3ds MAX 2019 only
Message 16 of 42
denisT.MaxDoctor
What are you searching for? You already have an hwnd for WinAPI methods and UI control to access its properties, such as material.
rt = pymxs.runtime
rt.clearListener()
mxsstr = '''
	on mbtest open do
		mb1.material = Standard name:#MAT_RED diffuse:red
		mb2.material = Standard name:#MAT_GRN diffuse:green
		mb3.material = Standard name:#MAT_BLU diffuse:blue
print(mxsstr)
rt.execute(mxsstr)
def procCh(wd):
    for cch in chArr:
                return cch
    chwnd = i.hwnd[0]
    print('hwnd:{0} control:{1} (by name >> {2}) mat:{3}'.format(chwnd, i, getattr(rt.mbtest, getattr(i, 'name')) ,getattr(i,'Material')))
    ##print(''.format(chwnd, i, '==', getattr(rt.mbtest, getattr(i, 'name')) , 'mat:', getattr(i,'Material'))
cWindow.show()
Message 17 of 42
inquestudios
So materialbuttons itself could not be accessed it qt at all, as they are NOT a QT widgets?
And how do I use winAPI with that? Can I override these buttons behavior, so they do not show material browser on left click and just check/uncheck like standard checkButton, but still with material drag and drop?
Message 18 of 42
denisT.MaxDoctor
they are not Qt...
Message 19 of 42
inquestudios
So can I disable material browser on left click?
On/off functinality could be made by switching button image with on_picked handler.
P.S. in 2019 if you click materialButton and without closing material browser click it again 3ds MAX crashes.
Bravo, Autodesk 👏👏👏
Message 20 of 42
denisT.MaxDoctor
Bravo, Autodesk 👏👏👏
Very unlikely... the material browser window that opens is modal, it doesn't allow you to click anything else...
