Automate - Convert FBX to DXF using 3Ds Max via plugin/CLI using C#/python
IPrtk
IPrtk
I have a FBX file dumped from an application. I want to export it into a DXF format file using the 3Ds Max programmatically via C#. Do we have any reference to convert this FBX file to DXF by executing the "Export As" plugin/executing the CLI with any parameters?
inquestudios
No need fooling around with C
You can do it easily with MAXscript
something like
importFile()
exportFile()
and you are done with it.
Have a look at MAXscript reference
https://help.autodesk.com/view/MAXDEV/2023/ENU/?guid=GUID-624D3D05-B15D-4A97-9F15-DA35CDB0DDD2#impor...
