I’m having a problem in 3ds max 2020 where I want to use the Projection modifier to project vertex colors from a high-density mesh onto a low-density one. Doing this by hand works fine. I have the beginnings of a script to automate it:
AddPModObjects #(projectorObj) true true objList:#(orig) proj = projectorObj.modifiers[#Projection] projMap = proj.getProjectionType 1 projMap.createNewHolder = true projMap.sameAsSource = true --Would like to set source channel here proj.projectAll()
The problem is that I don’t see how the source channel option is exposed to MaxScript. if I look at the docs or run showProperties on projMap, I see:
.name : string .holderName (Projection_Holder_Name) : string .alwaysUpdate (Always_Update_Holder) : boolean .createNewHolder (Create_New_Holder) : boolean .sourceMapChannel (Source_Map_Channel) : integer .sameAsSource (Same_as_Source) : boolean .targetMapChannel (Target_Map_Channel) : integer .projectMaterialIDs (Project_Material_IDs) : boolean .sameTopology (Same_Topology) : boolean .ignoreBackfacing (Ignore_Backfacing) : boolean .testSeams (Test_Seams) : boolean .checkEdgeRatios (Check_Edge_Ratios) : boolean .weldUVs (Weld_UVs) : boolean .weldUVsThreshold (Weld_UVs_Threshold) : float .edgeRatioThreshold (Edge_Ratio_Threshold) : float
The most similar one is `sourceMapChannel`, but changing that only changes the integer map channel for the “Map Channel” source type - the red X in my screenshot. How can I set the radio button for the green arrow, “Vertex Color” from maxscript?
You can always send a click to the control you want to trigger:
local projectorObj = ...
local orig = ...
local iGlobal = (dotNetClass "Autodesk.Max.GlobalInterface").Instance
fn sendClick hWnd =
local WM_LBUTTONDOWN = 0x0201
windows.postMessage hwnd WM_LBUTTONDOWN 0 0
windows.postMessage hwnd (WM_LBUTTONDOWN + 1) 0 0
SetCommandPanelTaskMode #modify
local proj = projectorObj.modifiers[#Projection]
proj.addRegisteredProjectionType 1
local cmdPanelWindows = windows.getChildrenHWnd ((iGlobal.UtilGetCoreInterface16()).CommandPanelRollup.Hwnd)
local vertexColorBtn = for item in cmdPanelWindows where
toLower (getFilenameFile (UIAccessor.getWindowDllFileName item[1])) == "projectionmodtypeuvw" and
UIAccessor.getWindowResourceID item[1] == 1073 do exit with item[1]
if isKindOf vertexColorBtn Number do sendClick vertexColorBtn
Yes, the modifier UI has to be ready to receive input.
I've asked this same question on the CG talk forums and got another answer:
projMap.sourceMapChannel = 0
Interestingly you can also use negative numbers to set the other radio buttons. Thanks for your involved answer all the same, @Swordslayer
