Hello there,
I created the following macroscript, with the intention of projecting UV map channel 2, from multiple selected objects (LOD0), to their corresponding low resolution objects (LOD1 and LOD2):
macroscript MyCustomTool2
category:"MyTools"
tooltip:"Project UVs multiple LOD0"
rollout projectMutipleUVsRollout "Project UVs"
button projectMutipleUVsButton "Project UVs"
on projectMutipleUVsButton pressed do
-- Retrieve the selected objects
local selectedObjects = selection as array
-- Check if any objects are selected
if selectedObjects.count > 0 then
-- Loop through each selected object
for z = 1 to selectedObjects.count do
-- Add Projection modifier to the selected object
local obj = selectedObjects[z]
local projMod = Projection ()
addModifier obj projMod
-- Get the name of the selected object
local objName = obj.name
-- Extract the base name
local baseName = substring objName 1 (objName.count - 1)
-- Iterate through all objects in the scene
for i = 1 to objects.count do
local currObj = objects[i]
local currObjName = currObj.name
-- Check if the object name matches the pattern
if (findString currObjName baseName) == 1 and (currObjName != objName) do
--Add the matched object to the Reference Geometry List
projMod.addObjectNode currObj
--Add a Projection Mapping
projMod.addRegisteredProjectionType 1
pMap = projMod.getProjectionType 1
--Get that Projection Mapping for work with it
--Assign UV map channels
pMap.sourceMapChannel = 2
pMap.sameAsSource = false
pMap.targetMapChannel = 2
projMod.projectAll()
-- Display a message
messageBox "UV projection completed."
else
-- Display a message if no objects are selected
messageBox "No objects selected." title:"Error"
createDialog projectMutipleUVsRollout 250 50
If I only select one object (LOD0), it works perfectly, but when I select multiple objects, I don't understand why, but "projMod.addRegisteredProjectionType 1" doesn't seem to work, and the code breaks after that. So, if any one could explain to me why these is happening, and give me some solution, I'll be really grateful. Thanks for your time.
Solved by denisT.MaxDoctor. Go to Solution.
Why code as a .PNG image? To have fun with the conversion?
Would you prefer an answer in ancient Egyptian to continue the fun?
the system tries to avoid a "dependency loop" and cannot add a target with an already added source as a target in another projection modifier. Thus, it is necessary to check and determine which targets should be excluded from the projection.
more specifically...
if the list of projected targets is empty, the projection modifier returns an undefined projection object with (pmod.getProjectionType 1)
for example:
mapped fn add_projection_mod obj targets: =
local pmod = Projection()
-- make the projection modifier a current edit object:
max modify mode
select obj
modPanel.addModToSelection pmod
if targets == unsupplied do targets = geometry as array
for target in targets do --> where not refs.DependencyLoopTest target obj do
----- the system checks for dependency loop >>
pmod.addObjectNode target
pmod.addRegisteredProjectionType 1 -- works only if pmod is a current edit ModPanel object:
if (pobj = pmod.getProjectionType 1) != undefined do
--format "object:% map:%\n" obj pobj
pobj.sourceMapChannel = 2
pobj.sameAsSource = false
pobj.targetMapChannel = 2
pmod.projectAll()
delete objects
for k=0 to 3 do box pos:[k*40,0,0]
select objects
add_projection_mod (selection as array)
Wow! That works perfectly! Thank you very much Denis! Just by reading and understanding a few lines of your code, I learned a lot, I really appreciate it man. Thank you for your time, and for all the time you have saved me.
I'll post my final code below, in case it helps anyone else.
macroscript MyCustomTool_001
category:"MyTools"
tooltip:"UV Channel Projection"
rollout projectMutipleUVsRollout "UV Channel Projection"
spinner sourceUV "Source UV Channel:" range:[1, 100, 2] type:#integer width:150 pos:[35,10]
spinner targetUV "Target UV Channel:" range:[1, 100, 2] type:#integer width:150 pos:[35,35]
button btnProjectUVs "Project UVs" width:150 height:30 pos:[25,70]
on btnProjectUVs pressed do
global val1 = sourceUV.value
global val2 = targetUV.value
local refList = #()
local pMod = Projection ()
--> go to modify mode
max modify mode
select obj
modPanel.addModToSelection pMod
-- Get the name of the possible target
local targetName = target.name
--Compare with the base name of the selected object
if (findString targetName baseName) == 1 and (targetName != objName) do
pMod.addObjectNode target
append refList target
pMod.addRegisteredProjectionType 1 -- works only if pmod is a current edit ModPanel object:
if (pMap = pMod.getProjectionType 1) != undefined do
pMap.sourceMapChannel = val1
pMap.targetMapChannel = val2
pMod.projectAll()
for ref in refList do ( collapseStack ref )
deleteModifier obj pMod
--Call function
add_projection_mod (selectedObjects)
else
createDialog projectMutipleUVsRollout 200 120
@denisT.MaxDoctor wrote:more specifically...
By the way, this sentence is incorrect. The projection target list (if it is empty, for example) does not affect the definition of the projection-type object. As I said in the code, the problem is that MXS has no method to add a registered projection type to an "inactive" modifier. The modifier must be selected as the current edit object in the modifier panel to initialize its local data and make the projection-type object defined.
