hi,
I need a way to measure a distance on a spline...
I add a normalize spline modifier to it with a unit of 1 (or alike)
I can easily get to the specific knot when I need a specific distance on that spline 😉
but now I realize that its absolutely not accurate, when you go through the knots (vertices) you will see it will add 1.02 (or alike) and at the end of the spline, inaccuracy added up so many times giving you bad measurements 🙂
is there any other way to exactly know how far a specific length is on a spline?
thanks a lot,
davy
