3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
mergeMaxFile, retain original layer?
1 REPLY 1
roger.olofsson
413 Views, 1 Reply
I am using "mergeMaxFile" to replace geometry in a bunch of files. I would like the objects to stay on the original layer but material and geometry should change, can that be done? Today geometry, material and layer is changed.
Roger
1 REPLY 1
blakestone
in reply to: roger.olofsson
mergeMAXFile will recreate the Layers.
You can also use #mergeDups which will replace existing objects which have the same name.
You can also use #useSceneMtlDups which means the newly merged objects will use existing materials.
example:
mergeMaxFile "c:\\example.max" #mergeDups #useSceneMtlDups quiet:true
Technical 3D Graphic Artist
Autodesk 3dsMax 2015 - Service Pack 4
