3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
Maxscript to convert standard materials to vray materials but retain animation on diffuse slot?
3 REPLIES 3
neilcooper33
1969 Views, 3 Replies
Hi All
I have an export from Synchro which has animated Standard materials which I need to convert to Vray materials and retain the animation keys in the diffuse color slot (see attached).
I can do this manually by picking the material, create new Vray material, and wiring in the bezier controller to the new vray material but i have thousands so looking for an automated way.
I've tried a couple of material converters but they don't bring across the animation.
if doing in maxscript, i think i need to.....
Get current object material
Create new vray material
Wire in old diffuse bezier node to new vray material
apply new material to object
repeat
thanks in advance!
Neil
Tags (1)
Labels (1)
3 REPLIES 3
i don't have VRay in my system but the solution can be as:
mapped fn convertStandardToVRayWithDiffuse mat = if iskindof mat Standard do
	vmat = VRayMtl name:mat.name showInViewport:mat.showInViewport
	if (c = getpropertycontroller mat #diffuseColor) != undefined do
		setpropertycontroller vmat #diffuse c
	replaceinstances mat vmat
	vmat
fn changeStandardMaterialsToVRay =
	mats = getclassinstances Standard
	convertStandardToVRayWithDiffuse mats
changeStandardMaterialsToVRay()
let me know if you meet any problems (errors, etc.)
thanks so much for this! will test this out later..... 🙂
in reply to: neilcooper33
I am doing exactly same thing. trying to change materials which came from Synchro to V-rayMat, but still cant transfer keys:(((
