3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
MaxScript CoronaMaterial Falloff and IOR
5 REPLIES 5
cfGVREN
1135 Views, 5 Replies
Hi all,
i need a MaxScript, which searches all used coronaMtl, changes ReflectIOR to 1.52 and all Falloff Maps Type to Perpendicular/Parallel.
This is what i have so far:
coronaMats = getClassInstances CoronaMtl
 for mat in coronaMats do
	mat.fresnelIor = 1.52
	mat.texmapReflect.type = 1
It works vor the IOR, but if after the Reflect Falloff map is something else (like CollerCorrection) i get an error...
what can i do/add?
Thank you!
Labels (1)
5 REPLIES 5
cfGVREN
in reply to: cfGVREN
Does anyone have an idea? 🙂
Swordslayer
cfGVREN
in reply to: Swordslayer
Doesnt seam to be the Solution 😞
There is no error message, if i use your code, but it is not changing the falloff map type...
I guess this time it is, because of the ColorMap at the end?
Here is an Image of my TestMaterial
Swordslayer
Oh, so you want to change it anywhere in the mat hierarchy? You can always do it like this:
(getClassInstances Falloff target:mat).type = 1
-- or (getClassInstances Falloff target:mat.texmapReflect).type = 1 if you want to limit it to that one slot
cfGVREN
Thats it! Thank you so much!
Technology Administrators
