Thanks!
Yes, the script is working. As you mentioned it still has some bugs as when changing views inside the viewport it seems to lose the connection.
Also when I use this script to rapid switch to the viewport closest to viewpoint angle in perspective/orthogonal view , the "slave" viewport seems to lose its focal point of view or something like that.
-- Created: 20-07-2017
-- Updated: 23-09-2017
-- Version: 1.10
-- Author : Roman Nazarov / [email protected] /
-- Description: Switch active viewport to the view closely aligned to the screen axis.
-- The analog of behavior of constrain angle snap in ZBrush.
-- Usage: SET SHORTCUT KEY ON THIS SCRIPT
-- Special thanks to Rustam Arazov (aka rustm) for providing an idea.
macroScript RotationAxisSnap
category: "jaspar scripts"
tooltip: "Switch active viewport to the view closely aligned to the screen axis"
global sType;
vpType = viewport.getType()
if (vpType==#view_left or vpType==#view_right or vpType==#view_front or vpType==#view_back or vpType==#view_bottom or vpType==#view_top)
then(
try(
viewport.setType sType
actionMan.executeAction 0 "40228" -- Views: Restore Active View
)catch()
else (
temp = viewport.getTM() as EulerAngles
sType = viewport.getType()
actionMan.executeAction 0 "40227" -- Views: Save Active View
case of
(45<=temp.y and temp.y<=135): viewport.setType #view_left
(-45>=temp.y and temp.y>=-135): viewport.setType #view_right
((-45>=temp.x and temp.x>=-135) and (-45<=temp.y and temp.y<=45)): viewport.setType #view_front
((45<=temp.x and temp.x<=135) and (-45<=temp.y and temp.y<=45)): viewport.setType #view_back
((135<=temp.x and temp.x<=180) or (-135>=temp.x and temp.x>=-180)): viewport.setType #view_bottom
default: viewport.setType #view_top
max zoomext sel
completeredraw()
But it works so
Thanks a lot!
