Link Two Viewports' View
rartidiello
Message 1 of 10
rartidiello
I need to link 2 viewports view. Let's say Active Viewport and Floating Viewport - 1.  Because I add a Viewport Filter in which I only show Editable Poly objects in the Active Viewport and Editable Mesh objects in the Floating Viewport, and need to see them both at the same time from the same angle.
So far I use a camera and show it in both viewports but I don't like it since moving, modeling and checking a scene through a camera view is quite a mess in my opinion.
I was thinking maybe saving a perspective/orthographic view from Active Viewport and pasting it to Floating Viewport - 1 every a short period of time and viceversa in case Floating Viewport - 1 becomes the Active Viewport.
Thanks!
Replies (9)
Message 2 of 10
denisT.MaxDoctor
Are you interested in learning how to do it, or are you looking for a working solution? 😉
Message 3 of 10
rartidiello
Right now more into a working solution 😁
Message 4 of 10
denisT.MaxDoctor
You are only working with one of the two linked viewports. The other one is needed for reference. If so, there is a safe way to link them - one would be a “free” viewport (static) and the other would be a camera view (floating).
Do you think this makes sense?
Message 5 of 10
rartidiello
Message 6 of 10
rartidiello
Ideally it would be great to work with both viewports as if one was an instance of the other. But a first approach could be that. Can you explain your method?
Message 7 of 10
denisT.MaxDoctor
try(destroydialog ViewBinderRol) catch ()
rollout ViewBinderRol "Bind Views by denisT" width:191
	local g = (dotnetclass "autodesk.max.globalinterface").instance
	local x = g.COREInterface14
	local vp0 = 3
	local vp1 = 7
	fn canbind =
		if x != undefined then
			x.GetViewExpByID vp0 != undefined and x.GetViewExpByID vp1 != undefined
		else false
	local binding = off
	local working_color = (color 51 128 204)
	local picking_color = orange
	checkbutton bind_callback_cb "Bind Viewports" width:172 align:#left offset:[-4,0] enabled:(canbind())
		tooltip:"Use Bound Viewports\n   RC\t- Pick A Pair to Active" highlightcolor:working_color
	fn bindViewports = if not binding do
		id = x.ActiveViewExp.ViewID
		if id == vp0 or id == vp1 do
			binding = on
			if id == vp1 do swap vp0 vp1
			v0 = x.GetViewExpByID vp0
			v1 = x.GetViewExpByID vp1
			v1.SetAffineTM v0.AffineTM
			v1.SetFOV v0.FOV
			v1.SetFocalDistance v0.FocalDist
			v1.Invalidate true
			binding = off
	fn disableViewportBinder ui:off =
		callbacks.removeScripts id:#viewport_binder
		unregisterRedrawViewsCallback bindViewports
		if ui do
			bind_callback_cb.state = off
			bind_callback_cb.highlightcolor = working_color
	fn enableViewportBinder ui:off =
		disableViewportBinder()
		binding = off
		callbacks.addscript #viewportChange "(getproperty ::ViewBinderRol #bindViewports)()" id:#viewport_binder
		bindViewports()
	fn pickBoundingPair =
		vp1 = x.ActiveViewExp.ViewID
		if (vp1 != vp0) do
			--xformat_ #active vp1
	on bind_callback_cb rightclick do
		if bind_callback_cb.state then
			disableViewportBinder ui:on
		else
			vp0 = x.ActiveViewExp.ViewID
			bind_callback_cb.state = on
			bind_callback_cb.highlightcolor = picking_color
			callbacks.addscript #activeViewportChanged "(getproperty ::ViewBinderRol #pickBoundingPair)()" id:#viewport_binder
	on bind_callback_cb changed state do
		if state then if canbind() do
			if canbind() then enableViewportBinder() else bind_callback_cb.state = off
		else disableViewportBinder ui:on
	on ViewBinderRol close do
	on ViewBinderRol open do
createdialog ViewBinderRol
The idea works... and the script almost works. But I purposely left the tools unfinished and left a couple bugs out to give you a chance to learn something. 😉
Message 8 of 10
rartidiello
Message 9 of 10
rartidiello
Thanks!
Yes, the script is working. As you mentioned it still has some bugs as when changing views inside the viewport it seems to lose the connection.
Also when I use this script to rapid switch to the viewport closest to viewpoint angle in perspective/orthogonal view , the "slave" viewport seems to lose its focal point of view or something like that.
-- Created: 20-07-2017
-- Updated: 23-09-2017
-- Version: 1.10
-- Author : Roman Nazarov / rnazarov@gmail.com /
-- Description: Switch active viewport to the view closely aligned to the screen axis.
-- The analog of behavior of constrain angle snap in ZBrush.
-- Usage: SET SHORTCUT KEY ON THIS SCRIPT
-- Special thanks to Rustam Arazov (aka rustm) for providing an idea.
macroScript RotationAxisSnap
category: "jaspar scripts"
tooltip: "Switch active viewport to the view closely aligned to the screen axis"
global sType;
vpType = viewport.getType()
if (vpType==#view_left or vpType==#view_right or vpType==#view_front or vpType==#view_back or vpType==#view_bottom or vpType==#view_top)
then(
try(
viewport.setType sType
actionMan.executeAction 0 "40228" -- Views: Restore Active View
)catch()
else (
temp = viewport.getTM() as EulerAngles
sType = viewport.getType()
actionMan.executeAction 0 "40227" -- Views: Save Active View
case of
(45<=temp.y and temp.y<=135): viewport.setType #view_left
(-45>=temp.y and temp.y>=-135): viewport.setType #view_right
((-45>=temp.x and temp.x>=-135) and (-45<=temp.y and temp.y<=45)): viewport.setType #view_front
((45<=temp.x and temp.x<=135) and (-45<=temp.y and temp.y<=45)): viewport.setType #view_back
((135<=temp.x and temp.x<=180) or (-135>=temp.x and temp.x>=-180)): viewport.setType #view_bottom
default: viewport.setType #view_top
max zoomext sel
completeredraw()
But it works so
Thanks a lot!
Message 10 of 10
denisT.MaxDoctor
@rartidiello wrote:
Thanks!
The main thing is not to give fish, but to teach how to catch them! 😉
