I'm trying to access by default protected dotNet Properties. I can't figure out how to use .GetProperty() with BindingFlags.
This is my current function:
fn doubleBuffered dgv args = (
--.<System.Type>GetType()
dgvType = dgv.GetType()
--.<System.Reflection.PropertyInfo>GetProperty <System.String>name
propertyReadOnly = dgvType.GetProperty("ReadOnly")
--.<System.Object>GetValue <System.Object>obj
propertyReadOnly.GetValue(dgv)
-- this works!
--.<System.Reflection.PropertyInfo>GetProperty <System.String>name <System.Reflection.BindingFlags>bindingAttr
flagInstance = (dotNetClass "System.Reflection.BindingFlags").Instance
flagNonPublic = (dotNetClass "System.Reflection.BindingFlags").NonPublic
propertyReadOnly = dgvType.GetProperty("DoubleBuffered" flagInstance or flagNonPublic)
-- Type error: Call needs function or class, got: "DoubleBuffered"
--next step
--.SetValue <System.Object>obj <System.Object>value
--.SetValue <System.Object>obj <System.Object>value <System.Object[]>index
--.SetValue <System.Object>obj <System.Object>value <System.Reflection.BindingFlags>invokeAttr <System.Reflection.Binder>binder <System.Object[]>index <System.Globalization.CultureInfo>culture
doubleBuffered dataGrid false
It seems that any additional property in .GetProperty() breaks the code.
Here is a sample code to try this with:
global doubleBufferForm (
if doubleBufferForm != undefined do doubleBufferForm.close()
pointClass = dotNetClass "System.Drawing.Point"
sizeClass = dotNetClass "System.Drawing.Size"
colorClass = (dotNetClass "System.Drawing.Color").fromARGB
doubleBufferForm = dotNetObject "maxCustomControls.MaxForm"
doubleBufferForm.Text = "DoubleBuffer Test"
doubleBufferForm.Size = dotNetObject sizeClass 900 600
doubleBufferForm.StartPosition = (dotNetClass "System.Windows.Forms.FormStartPosition").CenterScreen
borderPanel = dotnetobject "Panel"
borderPanel.Location = dotNetObject pointClass 5 5
borderPanel.Size = dotNetObject sizeClass 868 535
borderPanel.Anchor = dotNet.CombineEnums borderPanel.Anchor.Top borderPanel.Anchor.Bottom borderPanel.Anchor.Left borderPanel.Anchor.Right
borderPanel.Padding = dotNetObject "System.Windows.Forms.Padding" 1
doubleBufferForm.Controls.Add borderPanel
dataGrid = dotNetObject "DataGridView"
dataGrid.BorderStyle = dataGrid.BorderStyle.None
dataGrid.Dock = dataGrid.Dock.Fill
dataGrid.RowHeadersVisible = false
dataGrid.AutoSizeColumnsMode = dataGrid.AutoSizeColumnsMode.Fill
dataGrid.AllowUserToResizeRows = false
dataGrid.AllowUserToResizeColumns = true
dataGrid.AllowUserToOrderColumns = true
dataGrid.AllowUserToAddRows = false
dataGrid.ColumnHeadersHeight = 34
dataGrid.ColumnHeadersHeightSizeMode = dataGrid.ColumnHeadersHeightSizeMode.DisableResizing
dataGrid.BackgroundColor = colorClass 255 255 255
dataGrid.ForeColor = colorClass 0 0 0
dataGrid.ShowEditingIcon = false
dataGrid.ReadOnly = true
dataGrid.SelectionMode = dataGrid.SelectionMode.FullRowSelect
allColumnNames = #("First", "Second", "Third")
for columnName in allColumnNames do (
Column = dotNetObject "DataGridViewTextBoxColumn"
Column.HeaderText = columnName
dataGrid.Columns.Add Column
for _ = 1 to 1000 do (
newRow = dotnetobject "DataGridViewRow"
dataGrid.Rows.Add newRow
newRow.Cells.Item[0].Value = (substring (genguid()) 2 36)
newRow.Cells.Item[1].Value = (substring (genguid()) 2 36)
newRow.Cells.Item[2].Value = (substring (genguid()) 2 36)
borderPanel.Controls.Add dataGrid
doubleBufferForm.showModeless()
Thanks for any pointers on this.
