How to use dotNet .GetProperty() with BindingFlags
akarcode
akarcode
I'm trying to access by default protected dotNet Properties. I can't figure out how to use .GetProperty() with BindingFlags.
This is my current function:
fn doubleBuffered dgv args = (
--.<System.Type>GetType()
dgvType = dgv.GetType()
--.<System.Reflection.PropertyInfo>GetProperty <System.String>name
propertyReadOnly = dgvType.GetProperty("ReadOnly")
--.<System.Object>GetValue <System.Object>obj
propertyReadOnly.GetValue(dgv)
-- this works!
--.<System.Reflection.PropertyInfo>GetProperty <System.String>name <System.Reflection.BindingFlags>bindingAttr
flagInstance = (dotNetClass "System.Reflection.BindingFlags").Instance
flagNonPublic = (dotNetClass "System.Reflection.BindingFlags").NonPublic
propertyReadOnly = dgvType.GetProperty("DoubleBuffered" flagInstance or flagNonPublic)
-- Type error: Call needs function or class, got: "DoubleBuffered"
--next step
--.SetValue <System.Object>obj <System.Object>value
--.SetValue <System.Object>obj <System.Object>value <System.Object[]>index
--.SetValue <System.Object>obj <System.Object>value <System.Reflection.BindingFlags>invokeAttr <System.Reflection.Binder>binder <System.Object[]>index <System.Globalization.CultureInfo>culture
doubleBuffered dataGrid false
It seems that any additional property in .GetProperty() breaks the code.
Here is a sample code to try this with:
global doubleBufferForm (
	if doubleBufferForm != undefined do doubleBufferForm.close()
	pointClass = dotNetClass "System.Drawing.Point"
	sizeClass = dotNetClass "System.Drawing.Size"
	colorClass = (dotNetClass "System.Drawing.Color").fromARGB
	doubleBufferForm = dotNetObject "maxCustomControls.MaxForm"
	doubleBufferForm.Text = "DoubleBuffer Test"
	doubleBufferForm.Size = dotNetObject sizeClass 900 600
	doubleBufferForm.StartPosition = (dotNetClass "System.Windows.Forms.FormStartPosition").CenterScreen
	borderPanel = dotnetobject "Panel"
	borderPanel.Location = dotNetObject pointClass 5 5
	borderPanel.Size = dotNetObject sizeClass 868 535
	borderPanel.Anchor = dotNet.CombineEnums borderPanel.Anchor.Top borderPanel.Anchor.Bottom borderPanel.Anchor.Left borderPanel.Anchor.Right
	borderPanel.Padding = dotNetObject "System.Windows.Forms.Padding" 1
	doubleBufferForm.Controls.Add borderPanel
	dataGrid = dotNetObject "DataGridView"
	dataGrid.BorderStyle = dataGrid.BorderStyle.None
	dataGrid.Dock = dataGrid.Dock.Fill
	dataGrid.RowHeadersVisible = false
	dataGrid.AutoSizeColumnsMode = dataGrid.AutoSizeColumnsMode.Fill
	dataGrid.AllowUserToResizeRows = false
	dataGrid.AllowUserToResizeColumns = true
	dataGrid.AllowUserToOrderColumns = true
	dataGrid.AllowUserToAddRows = false
	dataGrid.ColumnHeadersHeight = 34
	dataGrid.ColumnHeadersHeightSizeMode = dataGrid.ColumnHeadersHeightSizeMode.DisableResizing
	dataGrid.BackgroundColor = colorClass 255 255 255
	dataGrid.ForeColor = colorClass 0 0 0
	dataGrid.ShowEditingIcon = false
	dataGrid.ReadOnly = true
	dataGrid.SelectionMode = dataGrid.SelectionMode.FullRowSelect
	allColumnNames = #("First", "Second", "Third")
	for columnName in allColumnNames do (
		Column = dotNetObject "DataGridViewTextBoxColumn"
		Column.HeaderText = columnName
		dataGrid.Columns.Add Column
	for _ = 1 to 1000 do (
		newRow = dotnetobject "DataGridViewRow"
		dataGrid.Rows.Add newRow
		newRow.Cells.Item[0].Value = (substring (genguid()) 2 36)
		newRow.Cells.Item[1].Value = (substring (genguid()) 2 36)
		newRow.Cells.Item[2].Value = (substring (genguid()) 2 36)
	borderPanel.Controls.Add dataGrid
	doubleBufferForm.showModeless()
Thanks for any pointers on this.
denisT.MaxDoctor
form = dotnetobject "Form"
type = form.GetType()
binding_flags = dotnetclass "System.Reflection.BindingFlags"
flags = dotnet.combineenums binding_flags.Instance binding_flags.NonPublic
prop = type.GetProperty "DoubleBuffered" flags
akarcode
Brilliant, it works as expected now. Those () really trolled me hard on this one 😅
Than you very much 🙏
denisT.MaxDoctor
Just to better understand what dotnet.combineenums does :
_convert = dotnetclass "System.Convert"
f1 = _convert.ToUInt64 _flags.Instance
f2 = _convert.ToUInt64 _flags.NonPublic
ff = _flags.ToObject _flags (f1 + f2)
akarcode
That is some nice additional tech info.
Also here is the documentation link: https://help.autodesk.com/view/MAXDEV/2022/ENU/?guid=GUID-9BE82D70-1869-46D7-9501-E5453E25AC68
Towards the bottom is 'Enums' information and a usage example.
It's also interesting how the BindingFlags are applied totally different depending on the Programming language.
Thanks again.
