it can be reduced something like this
#define TEMPLATE_UTIL_OBJ_CLASS_ID Class_ID(0xe823fa8, 0x21c0384c)
#define TEMPLATE_UTIL_OBJ_FP_INTERFACE_ID Interface_ID(0x436202d5, 0x70000ea6)
// TemplateUtilObj Our Tools class definition
class TemplateUtilObj : public UtilityObj
public:
HWND hPanel; // utility rollout panel
IUtil *iu;
Interface *ip;
HWND floaterHWND; // our floating window
// Constructor/Destructor
TemplateUtilObj();
~TemplateUtilObj() {}
// stuff for the utility panel
void BeginEditParams(Interface *ip,IUtil *iu);
void EndEditParams(Interface *ip,IUtil *iu);
// util panel
void Init(HWND hWnd) {}
void Destroy(HWND hWnd) {}
void DeleteThis() {}
// tool window handling routines
void CreateNewWindow();
void InitWindow();
void DestroyWindow();
void UpdateUI();
LRESULT NotifyHandler( HWND hWnd, UINT uMsg, WPARAM wParam, LPARAM lParam);
// our util global static
static TemplateUtilObj utilObj;
// the class descriptor
class TemplateUtilObjClassDesc : public ClassDesc2
public:
int IsPublic() { return TRUE; }
void * Create(BOOL loading=FALSE) { return &utilObj; }
const TCHAR * ClassName() { return GetString(IDS_TEMPLATE_CLASS_NAME); }
SClass_ID SuperClassID() { return UTILITY_CLASS_ID; }
Class_ID ClassID() { return TEMPLATE_UTIL_OBJ_CLASS_ID; }
const TCHAR* Category() { return GetString(IDS_CATEGORY); }
const TCHAR* InternalName() { return _T("TemplateUtilObj"); }
HINSTANCE HInstance() { return hInstance; } // returns owning module handle
static TemplateUtilObjClassDesc TemplateUtilObjDesc;
ClassDesc2* GetTemplateUtilObjDesc() { return &TemplateUtilObjDesc; }
// function publishing, make some basic functionality available to mxs mostly so we can call our
// utility from the ui via a macroscript without switching to the utility panel first !
class TemplateUtilObjFnP : public FPStaticInterface
public:
DECLARE_DESCRIPTOR(TemplateUtilObjFnP);
enum functionID { kOpenWindow, kCloseWindow, kIsOpen };
BEGIN_FUNCTION_MAP
VFN_0(kOpenWindow, OpenWindow)
VFN_0(kCloseWindow, CloseWindow)
FN_0(kIsOpen, TYPE_BOOL, IsOpen)
END_FUNCTION_MAP
void OpenWindow() { utilObj.CreateNewWindow(); }
void CloseWindow() { if(utilObj.floaterHWND) DestroyWindow(utilObj.floaterHWND); }
bool IsOpen() { return IsWindowOpen(); }
static bool IsWindowOpen() { return windowOpen; }
static void SetWindowOpen(bool val) { windowOpen = val; GetCUIFrameMgr()->SetMacroButtonStates(false); }
private:
static bool windowOpen;
// create the global static instance
static TemplateUtilObjFnP theTemplateUtilObjFnP(TEMPLATE_UTIL_OBJ_FP_INTERFACE_ID, _T("utilObj"),
IDS_TEMPLATE_CLASS_NAME, NULL, FP_CORE,
TemplateUtilObjFnP::kOpenWindow, _T("openWindow"), -1, TYPE_VOID, FP_NO_REDRAW, 0,
TemplateUtilObjFnP::kCloseWindow, _T("closeWindow"), -1, TYPE_VOID, FP_NO_REDRAW, 0,
TemplateUtilObjFnP::kIsOpen, _T("isOpen"), -1, TYPE_BOOL, FP_NO_REDRAW, 0, p_end);
// initialize the showing static
bool TemplateUtilObjFnP::windowOpen = false;
static INT_PTR CALLBACK TemplateUtilObjPanelProc(HWND hWnd, UINT msg, WPARAM wParam, LPARAM lParam)
switch (msg)
case WM_INITDIALOG:
utilObj.Init(hWnd); // can we delete these ?
break;
case WM_DESTROY:
utilObj.Destroy(hWnd); // can we delete these ?
break;
case WM_COMMAND:
switch (LOWORD(wParam))
case IDC_NEW_FLOATER_BTN:
break;
case IDOK:
case IDCANCEL:
DestroyWindow(hWnd);
break;
break;
case WM_LBUTTONDOWN:
case WM_LBUTTONUP:
case WM_MOUSEMOVE:
utilObj.ip->RollupMouseMessage(hWnd,msg,wParam,lParam);
break;
default:
return FALSE;
return TRUE;
// the main handler callback for our floating tool window
static INT_PTR CALLBACK TemplateUtilObjWindowProc(HWND hWnd, UINT msg, WPARAM wParam, LPARAM lParam)
switch (msg)
case WM_INITDIALOG:
utilObj.floaterHWND = hWnd;
utilObj.InitWindow();
utilObj.ip->RegisterDlgWnd(hWnd);
utilObj.UpdateUI();
TemplateUtilObjFnP::SetWindowOpen(true);
break;
case WM_DESTROY:
utilObj.DestroyWindow();
utilObj.ip->UnRegisterDlgWnd(hWnd);
TemplateUtilObjFnP::SetWindowOpen(false);
break;
case WM_RBUTTONDOWN:
break;
case WM_NOTIFY:
return utilObj.NotifyHandler(hWnd, msg, wParam, lParam);
break;
// handle custom max controls handled here spinners etc here e.g.
// case CC_SPINNER_CHANGE:
// case CC_COLOR_SEL:
// case CC_COLOR_CHANGE:
// case CC_COLOR_CLOSE:
case WM_COMMAND:
// all other win32 dialog handled here
case IDOK:
case IDCANCEL:
break;
break;
default:
return FALSE;
return TRUE;
// TemplateUtilObj, code for our utility starts here
TemplateUtilObj::TemplateUtilObj()
iu = NULL;
ip = NULL;
hPanel = NULL;
floaterHWND = NULL;
void TemplateUtilObj::BeginEditParams(Interface *ip,IUtil *iu)
this->iu = iu;
this->ip = ip;
hPanel = ip->AddRollupPage(hInstance, MAKEINTRESOURCE(IDD_TEMPLATE_WINDOW_PANEL),
TemplateUtilObjPanelProc, GetString(IDS_PARAMS), 0);
void TemplateUtilObj::EndEditParams(Interface *ip,IUtil *iu)
this->iu = NULL;
ip->DeleteRollupPage(hPanel);
hPanel = NULL;
void TemplateUtilObj::CreateNewWindow()
ip = GetCOREInterface(); // catches any script calls
if(floaterHWND == NULL)
CreateDialog(hInstance, MAKEINTRESOURCE(IDD_TEMPLATE_WINDOW), ip->GetMAXHWnd(), TemplateUtilObjWindowProc);
LRESULT TemplateUtilObj::NotifyHandler( HWND hWnd, UINT uMsg, WPARAM wParam, LPARAM lParam)
return 0L;
// Initialize the tool window
void TemplateUtilObj::InitWindow()
// destroy the tool window
void TemplateUtilObj::DestroyWindow()
floaterHWND = NULL;
void TemplateUtilObj::UpdateUI() {}
