3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
Edit UVWs texMap arrays out of sync?
0 REPLIES 0
Message 1 of 1
dmitriy.shpilevoy
270 Views, 0 Replies
I have multisub material. With macrorecorder enabled I can see how max creates texMapList and texMapIDList when I open EditUVWs window:
$.modifiers[#Unwrap_UVW].texMapList.count = 17
$.modifiers[#Unwrap_UVW].texMapIDList.count = 17
$.modifiers[#Unwrap_UVW].texMapList[1] = Checker ()
$.modifiers[#Unwrap_UVW].texMapIDList[1] = -1
$.modifiers[#Unwrap_UVW].texMapList[2] = Bitmaptexture fileName:"D:\SVN\...\xxx.tga"
$.modifiers[#Unwrap_UVW].texMapIDList[2] = 0
$.modifiers[#Unwrap_UVW].texMapList[17] = Bitmaptexture fileName:"D:\SVN\...\yyy.tga"
$.modifiers[#Unwrap_UVW].texMapIDList[17] = 13
$.modifiers[#Unwrap_UVW].TextureCheckerMaterial = PhysicalMaterial ()
Now comes confusing part. There are 2 checkers at the start of texture list: Texture Checker (UV_Checker.png) and CheckerPattern (Checker).
texMapList.count and texMapIDList.count both return 17 and if I try to get $.modifiers[#Unwrap_UVW].texMapList[18] it gives "undefined", but if I select last texture from the list manually, macrorecorder shows this action as
$.modifiers[#unwrap_uvw].unwrap.setCurrentMap 18
I can set 18th id, but can't get it from those arrays.
So is there another third array that stores proper values or how can I synchronize get/set states of texMap arrays?
Labels (1)
0 REPLIES 0
