3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
Center UVW map gizmo on object center
2 REPLIES 2
kenc
251 Views, 2 Replies
I would like a way to script the Align of UVW map to center of an object like in the UVW map dialog
TIA
kenc
2 REPLIES 2
denisT.MaxDoctor
in reply to: kenc
tm = $.modifiers[uvwmap].Gizmo.transform
tm.pos = $.center * (getModContextTM $ $.modifiers[uvwmap]) * (inverse $.objecttransform)
$.modifiers[uvwmap].Gizmo.transform = tm
I hope I didn't forget or mix up anything.
kenc
in reply to: kenc
@denisT.MaxDoctor it works perfectly. Thank you.
