Announcements
c# .net, drag and drop button to import .fbx and .obj file
dineshkUK68R
dineshkUK68R
I am simply trying to import .fbx, .obj and .dae files on custom UI buttons click. UI is very simple as You can see in the attached image. Each button has a file path.
Is it possible with 3ds max .net api?
If possible, please give me some link to study the document or some code snippets to understand the process for doing this.
As of now I am completely new and I am not getting any good references to study.
Please Help,
Thank you
istan
did you try google "3ds maxscript dotnet drag and drop"?
dineshkUK68R
yes, i have been tried.
but i got my solution through a guess from this link
https://forums.autodesk.com/t5/3ds-max-programming/c-net-drag-and-drop-button-to-import-fbx-and-obj-...
there is a line in this solution :- var layir = glob.COREInterface19.LayerManager.GetLayer("100_");
So,i started finding something in the global.COREInterface and i got ImportFromFile method in COREInterface14
IGlobal global = Autodesk.Max.GlobalInterface.Instance;
IInterface14 ip = global.COREInterface14;
var lays = global.COREInterface14.ImportFromFile(string name, bool suppressPrompts, IClass_ID importerID);
This is working on button click and I am able to import file but don't know this is the right way to do this or not.
Still looking for the documentation with dotnet.
Please provide me the link of dotnet documentation of 3dsmax 2019 sdk.
Thank you
istan
Sry, but your topic says dotnet drag/drop..
I'd simply call an MXS from C#..
ExecuteMaxscriptCommand() or so..
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/3DSMa...
dineshkUK68R
d&d is the final but it is fine for the time being it is working on button click.
I have no idea about maxscript, i will read on it.
Thanks for the link.
