3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
adding render elements with python?
3 REPLIES 3
1168 Views, 3 Replies
How would i go about adding a render element with python?
In maxscript
r = maxOps.GetCurRenderElementMgr()
r.AddRenderElement(CMasking_Mask)
And in python
r = MaxPlus.RenderSettings.GetCurrentRenderElementManager()
r.AddRenderElement()
Pythons AddRenderElement calls for the Class_ID, but i have zero idea how to get hold of that.
Cheers,
3 REPLIES 3
So I've managed to add a standard render pass, in this case Alpha
rndr_elem_mgr = MaxPlus.RenderSettings.GetCurrentRenderElementManager()
alpha_elem = MaxPlus.Factory.CreateRenderElement(MaxPlus.ClassIds.alpha)
rndr_elem_mgr.AddRenderElement(alpha_elem)
With that, how would i add render elements from 3rd party renderers? CMasking_Mask from Corona for instance.
Again, it works in maxscript with
r.AddRenderElement (CMasking_Mask elementname:"CMasking_Mask")
Cheers,
Swordslayer
If there's no predefined ClassID, construct the ClassID yourself with MaxPlus.Class_ID(idA, idB)
You can get the ClassID parts in the listener with CMasking_Mask.classID
in reply to: Swordslayer
Fantastic. That's a much better way. The solution i knocked together calling Maxscript from python and string format for params that i needed. But i'd much prefer to run straight python.
maxscript = """
    r.AddRenderElement (CMasking_Mask elementname:"CMasking_Mask_{}" mode:1 objectROn:true objectR:{} objectGOn:true objectG:{} objectBOn:true objectB:{})
""".format(inc, id[0], id[1], id[2])
MaxPlus.Core.EvalMAXScript(maxscript)
Thanks again,
