3DS Max 2025, NET Core 8.0 ERROR: my C# plugin as 3dsMax-Explode-Geometry (ver. 2024)'s template
tuiday17
Message 1 of 1
tuiday17
Dear Support Team,
  My plugin code:
using Autodesk.Max;
using UiViewModels.Actions;
namespace ADNExplodeGeometry
  public abstract class amdTplCmdClass : CuiActionCommandAdapter
    public override string ActionText
      get { return InternalActionText; }
    public override string Category
      get { return InternalCategory; }
    public override string InternalActionText
      get { return CustomActionText; }
    public override string InternalCategory
      get { return "DMD"; }
    public override void Execute(object parameter)
      try
        CustomExecute(parameter);
      catch (Exception ex)
        Debug.Print(ex.Message);
    public abstract string CustomActionText { get; }
    public abstract void CustomExecute(object parameter);
  }// class
  public class mdAboutTKD_MD : amdTplCmdClass
    public static string mdName = "DMD test";
    public override string CustomActionText
      get { return mdName; }
    public override void CustomExecute(object parameter)
      IGlobal g = Autodesk.Max.GlobalInterface.Instance;
      IInterface ip = g.COREInterface;
      ip.PushPrompt("Hello DMD!");
  } // class
}//namespace
I can see my plugin in 3DS Max 2025, but error when I start my command:
Could you help me fix this error or update new version for 3DS Max 2025 in "3dsMax-Explode-Geometry" (https://github.com/ADN-DevTech/3dsMax-Explode-Geometry)
Best Regards,
DMD
Replies (0)
