Check which decimal separator the system is using?
KasperFilipsen
KasperFilipsen
Is it possible to figure out through code what kind of decimal separator the windows system is using?
I've run into an issue when importing a DWG with a preset. If the preset doesn't use the same decimal separator as the system, it doesn't work correctly.
KasperFilipsen
I managed to figure out a solution with dotNet
decimalSeparator = (dotNetClass "System.Globalization.CultureInfo").CurrentCulture.NumberFormat.NumberDecimalSeparator
