When opening 3D Max this comes up in a dialogue box, which I close and then the program will open. When I select the rendering tab I get error messages and none of the functions. Once in a while it opens correctly. This is the message I get:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.TypeInitializationException: The type initializer for 'Ephere.Utilities.Evaluator' threw an exception. ---> System.IO.IOException: The process cannot access the file 'C:\Users\Frank\AppData\Local\Temp\fng1uf4b.dll' because it is being used by another process.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at Microsoft.JScript.JSCodeGenerator.FromFileBatch(CompilerParameters options, String[] fileNames)
at System.CodeDom.Compiler.CodeCompiler.FromSourceBatch(CompilerParameters options, String[] sources)
at System.CodeDom.Compiler.CodeCompiler.System.CodeDom.Compiler.ICodeCompiler.CompileAssemblyFromSourceBatch(CompilerParameters options, String[] sources)
at Ephere.Utilities.Evaluator..cctor()
--- End of inner exception stack trace ---
at Ephere.Utilities.Evaluator.EvalToDouble(String statement)
at Ephere.Gui.NodeViews.Skin.Area.GetLeftValue(Dictionary`2 parameterValues)
at Ephere.Gui.NodeViews.NodeView.Node.LayoutNodes()
at Ephere.Gui.NodeViews.Schematic.ValueNode.LayoutNodes()
at Ephere.Gui.NodeViews.Schematic.InternalInputsNode.LayoutNodes()
at Ephere.Gui.NodeViews.Skin.SetBoilerPlateSchematicView(Schematic view)
at Ephere.Gui.NodeViews.Skin.CreateBoilerPlateSchematicView()
at Ephere.Gui.NodeViews.Skin.InitializeSchematicNodeSkinFromBoilerPlateBitmaps(Bitmap[] boilerPlateBitmaps)
at Ephere.Gui.NodeViews.Skin.get_Default()
at Autodesk.Max.StateSets.Plugin..ctor()
at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
at System.Activator.CreateInstance(Type type, Boolean nonPublic)
at System.Activator.CreateInstance(Type type)
at Autodesk.Max.Manager.LoadAssembly(String name, Boolean startingUp)
at Autodesk.Max.Manager.LoadAssemblies()
How can I solve this. I have run a repair, reinstall, uninstall and then reinstall. Nothing works Can anyone assist? Thanks Frank
