Announcements
Wireframe not displaying right away
I'm writing a modifier which changes lots of things in a mesh, including geometry, topology and texture mapping.
It works well in the case of a smooth or facet rendering, but I have problems with the wireframe: I must move a viewport a little bit if I want the output mesh to be drawn.
As my modifier "animates" the object along with time, I am unable to preview the resulting animation in the viewport.
I specify that I change all these channels in the modifier specs, I invalidate the Geom and topo caches, I call the "PointsWereChanged" method and I update the associated validity...
Does anyone know which flag I miss ?
Thanks a lot for your help,
Best regards,
Etienne
Well, it works much better now !
the strange thing is that I changed something not related to wireframe: when creating the UV sets for my object, I was doing something like this:
for &#40;<all the desired UV maps>&#41;
mesh.InitMap&#40;&#41;
//fill in the map
Changing this code to this:
//fill in the map
solved everything... weird !
I've also noticed I get better results using the following at the end of my Modify method:
os->obj->UpdateValidity&#40; ChannelsChanged&#40;&#41;, valid &#41;
os->obj->SetChannelValidity&#40; TOPO_CHAN_NUM, valid &#41;
os->obj->SetChannelValidity&#40; GEOM_CHAN_NUM, valid &#41;
os->obj->SetChannelValidity&#40; TEXMAP_CHAN_NUM, valid &#41;
Where "valid" usually is set to Interval&#40;time,time&#41;.
Also, check your bounding box to make sure it is ok.
