Why does Custom Attribute definition register an Undo record?
denisT.MaxDoctor
Advisor Advisor
Message 1 of 16
denisT.MaxDoctor
run this snippet and see the undo list...
gc()
undo off
	attributes _attr attribid:#(0x0A0A0A, 0x000A)
		parameters params
	ok
you will see one record - "Custom Attribute Redefinition". Why?! I said: "UNDO OFF!". It works for everything except "ca definitions". Any idea how to suspend this hold?
(theHold.Suspend() doesn't work, everything that I tried doesn't work...)
ps. do "max undo" after that is not a solution, clear the undo buffer is not a solution as well.
pps. pps. of course, to get the "redefinition" you have to call it at least twice...
Replies (15)
Message 2 of 16
denisT.MaxDoctor
I can also ask - can we call it "redefinition", by the way? Same name, same identifier, same script...
But that's another story, I can get over it.
Message 3 of 16
MehdiZangenehBar
This works for me:
theHold.DisableUndo()
		parameters params
	ok
theHold.enableUndo()
This is wierd that undo context dosn't work!
Message 4 of 16
denisT.MaxDoctor
let's try another one:
gc()
thehold.disableundo()
	attributes __cca attribid:#(0x21111, 0x72111)
		parameters params
	attributes __caa attribid:#(0x51522, 0x5B222)
		parameters params
Message 5 of 16
MehdiZangenehBar
I'm not sure what is going on:
	gc()
	theHold.getUndoNames()
Message 6 of 16
larryminton
I'll log a defect on the creation of the undo record when redefining scripted CAs in this case, but it is complicated.
The 'with undo off' causes a context object that suspends the hold system to start to execute, then what is in the expression is executed, and then the hold system is resumed coming out. But that is all occurring during the execution of the script.
The scripted CA definition is not a run time operation, rather it occurs in the parser thread as the script is being 'compiled'.  So execution is not occurring at this time.
Going to be tricky to handle as since not executing the script, code has no way to know what the undo state is.  This is perfectly valid:
xxx = true
with undo xxx do
This is why you can't say something like the following, and expect executing the function to change the scripted CA definition.
fn def1 =
		parameters params
			hitPoints type:#float default:10
fn def2 =
		parameters params
			cost type:#float default:100
Larry Minton
Principal Engineer, M&E-Design Animation
Message 7 of 16
larryminton
note that this works, with expected undo records.
fn def1 =
	::XX = execute "attributes __cca attribid:#(0x21111, 0x72111)
		parameters params
fn def2 =
	with undo off ::XX = execute "attributes __cca attribid:#(0x21111, 0x72111)
		parameters params
def1()
XX.source
def2()
XX.source
Larry Minton
Message 8 of 16
denisT.MaxDoctor
this may explain the behaviour, but running this script we see that both Restore Objects and Hold record are added inside the code block, ignoring the fact that UNDO is suspended
undo off
		parameters params
	format "% % %\n" (thehold.IsSuspended()) (thehold.GetGlobalPutCount()) (thehold.getCurrentUndoLevels())
	ok
I can live with the fact that restore obejct can be put whithout UNDO available, but when the system does do it, I like to know what exacltly was regestered.
Message 9 of 16
denisT.MaxDoctor
It's not really a solution, and I don't think it needs to be solved at all, but explaining it suffices and makes sense to me:
"The 'with undo off' causes a context object that suspends the hold system to start to execute, then what is in the expression is executed, and then the hold system is resumed coming out."
Message 10 of 16
denisT.MaxDoctor
deleted
Message 11 of 16
denisT.MaxDoctor
Perhaps the only thing to note is that the multiple definitions should be stored as a block:
undo "DA" on
		parameters params
		parameters params
The above example creates two 'undo' records, when there should only be one.
Message 12 of 16
denisT.MaxDoctor
@larryminton wrote:
I'll log a ...
Thanks, Larry, for bringing some pieces of the MAX dump to light...
By the way, can we also expose some of the theHold MXS methods in the C++ SDK?
(like getMaxUndoLevels, getUndoNames ...)
Message 13 of 16
larryminton
those are exposed via the 'theHold' struct
Larry Minton
Message 14 of 16
denisT.MaxDoctor
I'm asking about the c++ sdk ... Or maybe I missed something? Could you please point to *.h or *.cpp file?
Message 15 of 16
larryminton
Ah, gotcha. Those are not exposed via public sdk.  I'll log a task to add them.
Larry Minton
Message 16 of 16
denisT.MaxDoctor
