Vray Sun and lights are not showing in Render
Message 1 of 14
Hello
I am trying to render my scene and I dont understand why it is very dark!
I have setup the Lights and VraySun but they are not lighting anything!
I added MrSky and the scene got a bit of lights.
I want the sun to cast shadows and to light the interior
Can you help?
I attached a render to show you how dark the scene is
Replies (13)
Message 2 of 14
@Anonymous
Please attach your file to take a look
Message 3 of 14
I have attached the file
Message 4 of 14
@Anonymous
س.PNGa.PNGGood now ?
i deleted previous sun and random lights near model and active vray sky light portal it's important so that sun Sun rays  ..
Message 5 of 14
I did what you said and it is still not the sun effect that i need.
I attached a picture to show what i want my render to look like
Message 6 of 14
@Anonymous
a.jpgYour problem with window glass (active affect shadows )light parameters.PNG , you control ( burn value  ) after that
Message 7 of 14
It is still not working! the sun is not showing at all even if I delete the windows
I think there is something wrong with my 3Ds Max I am using the 2015 version
Message 8 of 14
I am trying everything! I was even working on another file now the sun also disappeared from this one!!
I need help
Message 9 of 14
@Anonymous
Try to open this file and just (render) keeping all setting  and tell me what did you find
Message 10 of 14
Okay so when I opened the file I got 2 windows:
-The file was created using a student version of Autodesk. The use of these data by an educational institution or for commercial purposes is a violation of your Autodesk 3Ds Max license agreement.
-The MassFX authored on this file was created with a newer version of the plugins. Forward compatibility is not supported, so things might not behave properly.
I am using 3Ds Max 2015
Message 11 of 14
@Anonymous
I saved it in 2015 but v ray 3.6
Message 12 of 14
I have Vray 3.0
Message 13 of 14
Hello...replying in 2021 when I was looking for a solution and I did finally find it for me. The thing is that though I had the Vraysun in the scene, the latter was still dark...but when I pulled the sun closer to the objects in my scene, everything was good and well lit perfectly. Well hope this help.
Message 14 of 14
dg3duy
do not forget to mark the issue as solved!
