Visual Studio 2008 Express and Max 2010 Plugin Wizard Project Creation Failed
Hi all,
I am trying to write a Max exporter for my own model format. I followed the readme file on how to install the Max 2010 Plugin Wizard into Visual Studio Express 2008. However, when I try create a project using the wizard, I get this error in Visual Studio.
"Creating project 'maxProject1' ... project creation failed."
Anyone know why that would be?
Well I don't know why, but after I installed "Visual Assist X" visual studio was able to create the project correctly.
I had exactly the same Problem with the Project-Creation-Wizard-Files (3dsmaxPluginWizard.ico, 3dsmaxPluginWizard.vsdir, 3dsmaxPluginWizard.vsz) from the original DVD. The Files I found in another Post here in the forum finally worked:
Here is the Thread:
http://area.autodesk.com/forum/autodesk-3ds-max/sdk/reconfigurerecreate-max-8-sdk-appwizard-for-use-...
And here are the Files:
http://www.tdmpalace.com/teamtools/3dsmaxPluginWizard2008.rar
Good Luck,
Daniel
Is the 2008 version of the 3dsmaxPluginWizard valid to create projects for max 2010 ?
chris.p.johnson
when you copy those wizard files into the visual studio directory, make sure they are not set to be read only. Visual Studio will need to modify them.
