variable, open and save as scene troubles
manue154
manue154
 Hello everybody! i'm trying to make a maxscript to open a scene and save it, do you know where i'm wrong? because nothing is working 😞
by advance, thank you to make my dream become true...
-- prompt user to ask a number of a plan
 rollout LL_Layout "Enter Plan to open"
  edittext plan_name "plan"
  button open_plan "OPEN"
  on open_plan pressed do
   if plan_name.text != "" do
    -- get the number entered and make a variables:
    planName = plan_name.text
    camName = "108_"+ planName
    -- path for open scene:
    LoadPath = getFiles "E:\\"+camName+"\\"+camName+"*.max"
    -- path for save as scene
    SaveASPath = "E:\\Users\\"+camName+"\\"
   -- open last scene by date founded:
    if LoadPath .count == 1 do (
    for f in LoadPath do (loadMAXFile f)
    -- get the variable and make another:
    OldcamName = "Old_" + camName
    extName = "_v000.max"
    SaveFile = camName+extName
    saveScene = SaveASPath + SaveFile
    -- make folder:
    makeDir SavePath
    --  save as the scene  in the folder created:
    saveMaxFile saveScene
  )--end on
 )--end rollout
createDialog LL_Layout 250 75
manue154
a wonderful cat give me the solution, if someone somehere need it, read this, it's working:
global LL_Layout
try(destroyDialog LL_Layout)catch()
			LoadPath = getFiles ("E:\\"+camName+"\\"+camName+"*.max")
			if LoadPath.count == 1 do
					resetMaxFile #noPrompt
					loadMAXFile f quiet:true
					-- make folder:
					--	"SAVEPATH is not defiend.Use the proper variable."
					--	"makeDir SavePath"
					if makeDir SaveASPath == true then
						if (saveMaxFile saveScene quiet:true) == true then
							format "SAVED: %\n" saveScene
						else
							format "NOT SAVED: %\n" saveScene
					else
						format "Can't create folder: % \n" SaveASPath
	)--end on
)--end rollout
