UI for the walkthrough mode
Haider_of_Sweden
Message 1 of 19
Haider_of_Sweden
Hi!
I built a UI and gathered the necessary code, but I need help to put it together.
Macroscript that activates walkThrough + it needs to open the UI:
	on execute do
		if walkThroughOps.isActive == false then
		walkThroughOps.start()
	else
		walkThroughOps.stop()
	On isChecked return (walkThroughOps.IsActive)
 the UI:
rollout WalkThrough_Rollout "WalkThrough" width:600 height:267
	slider 'slider_rotSens' "Rotation Sensitivity" pos:[25,35] width:315 height:44 range:[1,100,40] ticks:1 align:#left
	slider 'slider_stepSize' "Step Size" pos:[25,95] width:315 height:44 range:[1,1000,50] ticks:1 align:#left
	button 'btn_LockHorizRot' "Lock Horizontal Rotation" pos:[360,180] width:55 height:55 align:#left
	button 'btn_LockVertRot' "Lock Vertical Rotation" pos:[435,180] width:55 height:55 align:#left
	button 'btn_InvertVertRot' "Invert Vertical Rotation" pos:[510,180] width:55 height:55 align:#left
	button 'btn_LevelView' "Level View" pos:[155,180] width:55 height:55 align:#left
	button 'btn_camUp' "Up" pos:[435,35] width:55 height:55 align:#left
	button 'btn_camDown' "Down" pos:[435,106] width:55 height:55 align:#left
	button 'btn_camLeft' "Left" pos:[360,64] width:55 height:55 align:#left
	button 'btn_camRight' "Right" pos:[510,65] width:55 height:55 align:#left
	button 'btn_accelToggle' "Accelleration Toggle" pos:[35,179] width:74 height:55 align:#left
	on slider_rotSens changed val do
			-- it works like this, eg walkThroughOps.sensitivity=1
			-- so we need the value from the slider to be reflected
	on slider_stepSize changed val do
			-- it works like this, eg walkThroughOps.stepSize=1000
	on btn_LockHorizRot pressed do
		actionMan.executeAction 1127307088 "50"  -- WalkThrough: Lock Horizontal Rotation
	on btn_LockVertRot pressed do
		actionMan.executeAction 1127307088 "48"  -- WalkThrough: Lock Vertical Rotation
	on btn_InvertVertRot pressed do
		actionMan.executeAction 1127307088 "53"  -- WalkThrough: Invert Vertical Rotation Toggle
	on btn_LevelView pressed do
		actionMan.executeAction 1127307088 "47"  -- WalkThrough: Level
	on btn_camUp pressed do
		actionMan.executeAction 1127307088 "51"  -- WalkThrough: Up
	on btn_camDown pressed do
		actionMan.executeAction 1127307088 "52"  -- WalkThrough: Down
	on btn_camLeft pressed do
		actionMan.executeAction 1127307088 "19"  -- WalkThrough: Left
	on btn_camRight pressed do
		actionMan.executeAction 1127307088 "21"  -- WalkThrough: Right
	on btn_accelToggle pressed do
	-- not sure if you can have a on execute and on isChecked.
	-- But we need this one to be pressed if this mode is on. Or a color
	-- change on the button or somethign indicating it is on.
	--on execute do
			if walkThroughOps.accelerate == true then
			walkThroughOps.accelerate=false
			format "Accellerate Off   "
		else
			walkThroughOps.accelerate=true
			format "Accellerate On  "
	--On isChecked return (walkThroughOps.accelerate)
Would be even better if it would be dockable (I might redo the design once I see it in action)
Replies (18)
Message 2 of 19
denisT.MaxDoctor
Here is a snippet that shows how I would do something like your task...
try (destroydialog ::EZ_WALK_STRUCT.dialog) catch()
macroscript WalkThroughUI
	tooltip:"EZ Walk Through"
	buttontext:"EZ WALK"
	category:"with denisT"
	silentErrors:on
	struct walkthrough_struct
		opened = off,
		dialog =
			rollout dialog "EZ Walk" width:191
				local owner = owner
				local updating = on
				timer walk_timer  interval:200 active:off
				group ""
					checkbox enabled_ch "Enabled" checked:walkthroughops.isEnabled offset:[0,-4]
					checkbutton active_cb "Active" checked:walkthroughops.isActive highlightColor:(orange*0.8) width:173 align:#left offset:[-4,2]
				group "Settings: "
					checkbox vert_lock_ch "Lock Vectical" checked:walkthroughops.lockVertical align:#left offset:[0,2]
					checkbox horz_lock_ch "Lock Horizontal" checked:walkthroughops.lockHorizontal align:#left offset:[0,0]
					checkbox accelerate_ch "Accelerate" checked:walkthroughops.accelerate align:#left offset:[0,4]
					spinner step_size_sp "Step Size: " type:#float range:[0, 1e6, walkthroughops.stepSize] fieldwidth:56 align:#right offset:[4,0]
					spinner sensitivity_sp "Sensitivity: " type:#float range:[0, 1e6, walkthroughops.sensitivity] fieldwidth:56 align:#right offset:[4,0]
				group "Navigation: "
				local ui_controls =
					#(enabled_ch, 		#checked, 	#isEnabled),
					#(active_cb, 		#checked, 	#isActive),
					#(vert_lock_ch, 	#checked, 	#lockVertical),
					#(horz_lock_ch, 	#checked, 	#lockHorizontal),
					#(accelerate_ch, 	#checked, 	#accelerate),
					#(step_size_sp, 	#value, 	#stepSize),
					#(sensitivity_sp, 	#value, 	#sensitivity)
				fn updateUI id:#get =
					updating = on
					if id == #set then
						for c in ui_controls do if (v = getproperty c[1] c[2]) != getproperty walkthroughops c[3] do setproperty walkthroughops c[3] v
					else if id == #get then
						for c in ui_controls do if (v = getproperty walkthroughops c[3]) != getproperty c[1] c[2] do setproperty c[1] c[2] v
					else
						c = ui_controls[id]
						setproperty walkthroughops c[3] (getproperty c[1] c[2])
					updating = off
				on walk_timer tick do if not updating do
					updateUI()
					--updateToolbarButtons()
				on active_cb changed state do
					if state and not walkthroughops.isactive do
						walkthroughops.start()
					if not state and walkthroughops.isactive do
						walkthroughops.stop()
						max select
					updateUI()
				on vert_lock_ch changed state do updateUI id:3
				on horz_lock_ch changed state do updateUI id:4
				on accelerate_ch changed state do updateUI id:5
				on step_size_sp changed value do updateUI id:6
				on sensitivity_sp changed value do updateUI id:7
				on dialog close do
					walk_timer.active = off
					owner.opened = off
				on dialog open do
					owner.opened = on
					walk_timer.active = on
					updating = off
		fn distroy =
			destroydialog dialog
		fn create =
			createdialog dialog
		on create do
			try
			catch()
			global EZ_WALK_STRUCT = dialog.owner = this
	local walkthrough_str = walkthrough_struct()
	on isenabled do
	on ischecked do
		walkthrough_str.opened
	on execute do
		if not walkthrough_str.opened then walkthrough_str.create() else walkthrough_str.distroy()
You need to add navigation functionality, storing/restoring dialog recent placement and dock state, and maybe something else
Message 3 of 19
Haider_of_Sweden
Thank you very much @denisT.MaxDoctor
This is a very beautiful solution.
I will mark the post as a solution and if anyone who sees this wants to add features to it, please share your solution with the community by posting a reply here.
Message 4 of 19
denisT.MaxDoctor
I was interested in this task, although I don’t see much point in such a substitution ... but nevertheless.
I'm assuming you want by pressing (releasing) a button to simulate typing DOWN/UP arrow keys (up, down, left, right)?
Built-in rollout button controls cannot work this way. They capture focus. They must be released to release the focus. Here's how they're made. Maybe ImgTags can be used instead. Or it's probably possible to use .Net or Qt buttons. But they also need to be set to something other than the default.
Message 5 of 19
Haider_of_Sweden
You're right Denis - the navigation itself is of little use. I made that mockup to have something to work on.
The commands were taken from the macroscripts below.
What is of bigger use is the possibility to dock and store its dock location upon the next Max launch.
This should be something rather common, no? Do you have the time to make your EZ Walk dockable?
Message 6 of 19
denisT.MaxDoctor
I'm not an art content developer, so I don't (almost never) use the Walk Through navigation mode.
Could you (or someone else) explain to me who the target users are and how they typically use it?
Why a custom UI for the Walk Through might be better or more useful than the MAX built-in solution?
Is the built-in missing some useful features?
Message 7 of 19
Haider_of_Sweden
The features you added are probably enough. Additions like a dockable window would make it more usable (people would use it more often).
As for who is the target user; people working with archviz or one way or another need to control the camera. Compared to the viewport that you can control with hotkeys, press Z to zoom in to selected objects, etc, the camera won't give you all the keyboard hotkey controls.
Sometimes I select the target and move it around.
But the best way, in my opinion, is using Walkthrough mode. Until your UI, being able to change the speed was tedious because you had to press Increase/Decrease so many times until you finally reached the speed you needed.
Message 8 of 19
denisT.MaxDoctor
The scenario you describe, however strange it may seem, has little to do with the built-in walkthrough mechanism. In walkthrough, the most and fundamentally important thing is to keep the speed of movement (this uses a quite complicated asynchronous timer). It's very easy to just move the camera (or change camera (view) transform) using custom UI. Moreover, we could not only translate the camera, but also rotate, spin, or orbit it. The maintaining the speed (keep specified timing) is necessary for walkthrough to set transform keys correctly, and if you don't care about it, everything becomes much easier. The camera control functionality can be significantly improved and expanded compared to the built-in walkthrough.
Message 9 of 19
klvnk
a little fun script for walkthrough.....
-- file: surface_walker_demo.ms
-- about: creates a terrain mesh with RayMeshGridIntersect custom attribute which is used as a collision detection in
-- viewport redraw callback and walkthrough mode.
rayGrid= attributes raygrid_attr_desc
attribID:#(0x4d193339, 0x60f3f7b8)
	local cGrid = undefined;
	parameters main rollout:params
		gridsize type:#float ui:gridsize_spnr default:100.0;
	fn IsRayGridInitialized = (cGrid != undefined);
	fn Initialize obj size:100 =
		gridsize = size;
		if cGrid != undefined then
			cGrid.free();
		else
			cGrid = RayMeshGridIntersect();
		cGrid.Initialize gridsize;
		cGrid.addNode obj;
		cGrid.buildGrid();
	fn getNode = refs.dependentnodes (custAttributes.getOwner this) firstonly:on
	rollout params "Ray Mesh Grid Params"
		button delete_btn images:#("enss_tools_16i.bmp", "enss_tools_16a.bmp", 13, 3, 3, 4, 4, true) across:2 align:#left offset:[-2,0]
		spinner gridsize_spnr "Grid Size:" range:[0.0, 10000.0, 0] fieldwidth:48 type:#float scale:1.0 align:#right offset:[0,3]
		on gridsize_spnr entered fromspinner canceled do
			if not canceled then Initialize (getNode()) size:gridsize;
		on delete_btn pressed do
			if cGrid != undefined do
				cGrid.free();
			gc();
			custAttributes.delete (getNode()) rayGrid;
struct SurfWalkerInterface
private
	sw_surface_walk_mode = off,
	sw_surface_object = undefined,
	sw_surface_offset = 1.93212,
	sw_yshift = 2.43396,
	sw_surface_script =	"tempI.sw_surface_following_vpcb()",
	sw_surface_fov = 84.0,
	sw_surface_savefov,
	sw_command_mode,
public
	fn setSurfaceWalkObj obj 		= (sw_surface_object = obj),
	fn getSurfaceWalkObj 			= (sw_surface_object),
	fn setSurfaceWalkMode mde 		= (sw_surface_walk_mode = mde),
	fn getSurfaceWalkMode  			= (sw_surface_walk_mode),
	fn getSurfaceWalkfov			= (sw_surface_fov),
	fn setSurfaceWalkfov fov		= (sw_surface_fov = fov),
	fn getSurfaceWalksavefov		= (sw_surface_savefov),
	fn setSurfaceWalksavefov fov	= (sw_surface_savefov = fov),
	fn sw_surface_following_vpcb = if not isdeleted sw_surface_object do
		tm = inverse (viewport.getTM());
		i = sw_surface_object.cGrid.intersectRay (tm.row4) [0,0,-1.0] false;
		if i != 0 then
			ipos = (tm.row4) + [0,0,-1.0] * sw_surface_object.cGrid.getHitDist i;
			tm.row4 = ipos + [0,0,sw_surface_offset];
			viewport.setTM (inverse tm);
		gw.hRect (box2 10 10 10 10) red;
		gw.hText [25,6,0] "surfwalker on" color:black
	on create do sw_surface_object = undefined;
tempI = SurfWalkerInterface();
fn CreateScene =
	p = plane width:200 length:200 lengthsegs:100 widthsegs:100 pos:[0,0,0];
	p.mat = standard();
	p.wirecolor = color 32 32 48;
	m = Noisemodifier fractal:true strength:[0.0,0.0,20.0];
	addModifier p m;
	converttoPoly p;
	viewport.setLayout #layout_1;
	viewport.setType #view_persp_user;
	viewport.setTM (matrix3 [0.754708,-0.140881,0.640756] [0.656061,0.162066,-0.737102] [-1.2964e-006,0.976671,0.214739] [-14.1606,6.68998,-114.909]);
	if (viewport.getGridVisibility viewport.activeViewport) then max grid toggle;
	viewport.SetShowEdgeFaces true;
	TargetDirectionallight rgb:(color 255 255 255) transform:(matrix3 [1,0,0] [0,0,1] [0,-1,0] [107.367,-3.44621e-006,78.84]) target:(Targetobject transform:(matrix3 [1,0,0] [0,1,0] [0,0,1] [0,0,0]))
	hide lights;
	tempI.setSurfaceWalkObj p;
	custAttributes.add p rayGrid;
	p.initialize p;
	tempI.setSurfaceWalkMode on;
	registerRedrawViewsCallback tempI.sw_surface_following_vpcb;
	tempI.setSurfaceWalksavefov (viewport.GetFOV());
	viewport.SetFOV (tempI.getSurfaceWalkfov());
	walkThroughOps.start();
unRegisterRedrawViewsCallback tempI.sw_surface_following_vpcb;
delete objects;
CreateScene();
-- uncomment the next line and evaluate the script to exit the terrain following mode
-- unRegisterRedrawViewsCallback tempI.sw_surface_following_vpcb
Message 10 of 19
Haider_of_Sweden
The Walkthrough tool is indeed useful for looking and walking.
Other tools have similar features, for example, Sketchup
Or Revit
What I was missing was a proper way to adjust the speeds.
But I might be missing something. What else would you suggest can be done with Walkthrough?
Again, I don't know what you know - if you have any examples of how to improve and expand the camera functionality, please do share some examples and solutions.
As a non-developer, I don have any insights into the possibilities, but love to see them 🙂
Message 11 of 19
Haider_of_Sweden
Wow! This is soo cool!
Thanks for sharing!
Three questions:
1) After turning it off
How can I turn it on again without evaluating the whole code? The code does generate the terrain and all, but since its already there, I assume you can just bring back the view onto the terrain
2) How can I use this to attach the "person" onto a given terrain?
This "fun script" is a game-changer in ways - you can control the movement in relation to a surface that is missing right now
3) I assume you can activate this feature with a camera too.
If you have the time, I would love to see a small UI that lets you pick a surface to walk on + exposing values like sw_surface_offset etc
Message 12 of 19
denisT.MaxDoctor
here is a very simple example how to navigate the active viewport...
you can play with the parameters and implement FOV and ZOOM if you like.
try(destroydialog ViewNavigatorDialog) catch()
rollout ViewNavigatorDialog "Viewport Navigation" width:191
	timer mover_tm active:off interval:50
	dotnetcontrol cam_up_bt    "Button" text:"Up" width:56 height:23 align:#center offset:[0,2]
	dotnetcontrol cam_left_bt  "Button" text:"Left" width:56 height:23 align:#left offset:[-5,0] across:3
	dotnetcontrol cam_front_bt "Button" text:"Front" width:56 height:23 align:#center offset:[0,0]
	dotnetcontrol cam_right_bt "Button" text:"Right" width:56 height:23 align:#right offset:[4,0]
	dotnetcontrol cam_down_bt  "Button" text:"Down" width:56 height:23 align:#center offset:[0,0]
	dotnetcontrol cam_back_bt  "Button" text:"Back" width:56 height:23 align:#center offset:[0,4]
	dotnetcontrol cam_fov_bt   "Button" text:"FOV" width:56 height:23 align:#center offset:[0,4] enabled:off
	dotnetcontrol cam_zoom_bt  "Button" text:"Zoom" width:56 height:23 align:#center offset:[0,0] enabled:off
	dotnetcontrol cam_yaw_bt "Button" text:"Yaw" width:56 height:23 align:#center offset:[0,4]
	dotnetcontrol cam_pitch_bt "Button" text:"Pitch" width:56 height:23 align:#center offset:[0,0]
	dotnetcontrol cam_roll_bt "Button" text:"Roll" width:56 height:23 align:#center offset:[0,0]
	local navigation_controls =
		cam_front_bt, cam_back_bt, cam_left_bt, cam_right_bt, cam_up_bt, cam_down_bt,
		cam_yaw_bt, cam_pitch_bt, cam_roll_bt,
		cam_fov_bt, cam_zoom_bt
	local tick_time = -1
	local can_move = false
	local inverse_action = off
	local current_action = #none
	fn navigate =
		can_move = (tick_time > 0)
		tm = getviewtm()
		tm = inverse tm
		h = 0.1 ---------------- set STEP SIZE (might be different for MOVE and ROTATE action)
		if inverse_action do h *= -1
		if keyboard.controlPressed do h *= 4
		if keyboard.shiftPressed do h *= 0.5
		t = timestamp()
		delta = t - tick_time
		tick_time = t
		if can_move do
			a = h*delta
			tm = case current_action of
				  #yaw: prerotatey tm a
				#pitch: prerotatex tm a
				 #roll: prerotatez tm a
				   #up: pretranslate tm [0, -a,  0]
				 #down: pretranslate tm [0, a,  0]
				 #left: pretranslate tm [a,  0,  0]
				#right: pretranslate tm [-a, 0,  0]
				#front: pretranslate tm [0,  0,  a]
				 #back: pretranslate tm [0,  0, -a]
			   default: tm
			tm = inverse tm
			viewport.settm tm
	on mover_tm tick do navigate()
	fn onMouseDown s a action:#move =
		tick_time = timestamp() - mover_tm.interval
		inverse_action = (s.mouseButtons != s.mouseButtons.Left)
		current_action = action
		--format "mouse down\t % %\n" s a
		mover_tm.active = on
		navigate()
	fn onMouseUp s a =
		tick_time = -1
		mover_tm.active = off
		--format "mouse up...\n"
	on cam_front_bt mouseDown s a do onMouseDown s a action:#front
	on cam_back_bt  mouseDown s a do onMouseDown s a action:#back
	on cam_left_bt  mouseDown s a do onMouseDown s a action:#left
	on cam_right_bt mouseDown s a do onMouseDown s a action:#right
	on cam_up_bt    mouseDown s a do onMouseDown s a action:#up
	on cam_down_bt  mouseDown s a do onMouseDown s a action:#down
	on cam_fov_bt   mouseDown s a do onMouseDown s a action:#fov
	on cam_zoom_bt  mouseDown s a do onMouseDown s a action:#zoom
	on cam_yaw_bt   mouseDown s a do onMouseDown s a action:#yaw
	on cam_pitch_bt mouseDown s a do onMouseDown s a action:#pitch
	on cam_roll_bt  mouseDown s a do onMouseDown s a action:#roll
	on cam_front_bt mouseUp s a do onMouseUp s a
	on cam_back_bt  mouseUp s a do onMouseUp s a
	on cam_left_bt  mouseUp s a do onMouseUp s a
	on cam_right_bt mouseUp s a do onMouseUp s a
	on cam_up_bt    mouseUp s a do onMouseUp s a
	on cam_down_bt  mouseUp s a do onMouseUp s a
	on cam_fov_bt   mouseUp s a do onMouseUp s a
	on cam_zoom_bt  mouseUp s a do onMouseUp s a
	on cam_yaw_bt   mouseUp s a do onMouseUp s a
	on cam_pitch_bt mouseUp s a do onMouseUp s a
	on cam_roll_bt  mouseUp s a do onMouseUp s a
	mapped fn initButton bt =
		bt.backcolor = if bt.enabled then bt.backcolor.LightGray else bt.backcolor.Gray
		bt.FlatStyle = bt.FlatStyle.Flat
	on ViewNavigatorDialog open do
		initButton navigation_controls
createdialog ViewNavigatorDialog
all buttons work the same:
Left press - action
Right press - inverse action
+ CTRL - faster
+ SHIFT - slower
Release - stop action
Message 13 of 19
denisT.MaxDoctor
I see that some possible improvements could be added:
RESET/ALIGN
ACCELERATION/DECELERATION
INERTIA/DAMPING
SNAPPING
Message 14 of 19
Haider_of_Sweden
Thank you very much for this addition. 😻
(Sorry for not replying immediately, I am not ungrateful, just so much else that calls for my attention)
Your previous tool, EZ Walk is compatible with cameras.
Do you know why this latter one, the Viewport Navigation, is only supported by the viewport and not cameras?
RESET/ALIGN
INERTIA/DAMPING
SNAPPING
All improvements are welcome. 😀
Also, @klvnk - if you are around.
could you please have a look at my latest reply to your post:
https://forums.autodesk.com/t5/3ds-max-programming/ui-for-the-walkthrough-mode/m-p/11128457/highligh...
Thank you! 🙏
Message 15 of 19
Swordslayer
Since you mention Revit and its navigation wheel which has a direct counterpart in max, I take it you already tried using that one (Views > SteeringWheels > Toggle SteeringWheels (Shift+W))?
Message 16 of 19
domo.spaji
I didn't want to ruin the fun  😁
In AutoCad also
Message 17 of 19
Haider_of_Sweden
Yes, and the same thing is missing with the Steering Wheel; the ability to read and set the value for the walk speed. That goes for all the Autodesk tools that offer the Steering Wheel. You're forced to fiddle with the value until you find a good speed.
With that said, I find the steering wheel useful for its other features.
@Swordslayer and @denisT.MaxDoctor
Any chance you could help me with klvnk's script?
Copy paste of the questions I had:
1) After turning it off...
3) I assume you can activate this feature with a camera too, how?
Message 18 of 19
Swordslayer
SteeringWheelsOps.SpeedFactor = xyz
SteeringWheelsOps.IncreaseWalkSpeed()
SteeringWheelsOps.DecreaseWalkSpeed()
Message 19 of 19
Haider_of_Sweden
So how would you set a speed?
I ran SteeringWheelsOps.IncreaseWalkSpeed() a couple of times, and then SteeringWheelsOps.SpeedFactor and I got the same number (speed value?) no matter how much I increased or decreased.
