Tv property from IMeshMap returns wrong value format
I tried the get vertex alpha values from a mesh using DotNet SDK, but something strange happened to me.
Indeed, to get theses alpha values, i need to check the mesh map at channel -2, then check its textures vertices...
The problem is, the Tv (textures vertices) property in IMeshMap doesn't return the same thing than in C++ SDK.
In DotNet it returns an IPoint3 instance (equivalent to UVVert), but in C++ SDK it's an Array of UVVert !
What do i need to do to find my values ?
Thank you.
I have finally found a workaround. I always think there's a mistake in the DotNet wrapper about what kind of data returns the Tv property.
My workaround was to handle my mesh as a IMNMesh instead of IMesh (more functionalities but slower operations).
if (!triObj.Mesh.MapSupport(-2))
    triObj.Mesh.SetMapSupport(-2, true);
IMNMesh mnmesh = MaxInterfaces.Global.MNMesh.Create(triObj.Mesh);
IMNMap alphaMap = mnmesh.M(-2);
if (alphaMap.Numv > 0)
    for (int i = 0; i < alphaMap.Numv; i++)
        MaxUtils.MxsLogger(string.Format("Alpha value for vertex {0} : {1}", i.ToString(), alphaMap.V(i).X.ToString()));
klvnk
what happens when you access them from the base mesh not through the meshmap  using?
mesh.mapVerts(-2);
jackwakefield
This is still an issue in 2022. Is there a place where we can report these issues? There seems to be a lot of bugs in the .NET SDK.
