trackview opacity
trackview opacity
yun7928903
trackview opacity
yun7928903
Is there any way to make the trackview transparent like when we try to dock it?
animator
  • code
yun7928903
in the lower version of max, I can use:
HiddenDOSCommand ("python G:\\trackviewAlpha.py") donotwait:true startpath:"c:\\"
to run a py:
import win32gui
import win32con
import winxpgui
import win32api
import subprocess
import time
hwnd = win32gui.FindWindow(None, "cometTrackview") ## name
win32gui.SetWindowLong (hwnd, win32con.GWL_EXSTYLE, win32gui.GetWindowLong (hwnd, win32con.GWL_EXSTYLE ) | win32con.WS_EX_LAYERED )
winxpgui.SetLayeredWindowAttributes(hwnd, win32api.RGB(0,0,0), 180, win32con.LWA_ALPHA)
to get the transparent track view. But in 2018 there seems to have been a callback. will make the track view not transparent again..ORZ
if I write another callback against the system callback seems too silly...
and it's very slow (=′ー`)
animator
denisT.MaxDoctor
fn CreateUser32AssistAssembly =
	source = "using System;\n"
	source += "using System.Runtime.InteropServices;\n"
	source += "class Wind32Assists\n"
	source += "{\n"
	source += "		[DllImport(\"user32.dll\", EntryPoint=\"UpdateWindow\")]\n"
	source += "		public static extern bool UpdateWindow(IntPtr hWnd);\n"
	source += "		[DllImport(\"user32.dll\", EntryPoint=\"GetWindowLong\")]\n"
	source += "		public static extern Int32 GetWindowLong(IntPtr hWnd, Int32 index);\n"
	source += "		[DllImport(\"user32.dll\", EntryPoint=\"SetWindowLong\")]\n"
	source += "		public static extern Int32 SetWindowLong(IntPtr hWnd, Int32 index, Int32 newVal);\n"
	source += "		[DllImport(\"user32.dll\")]\n"
	source += "		public static extern bool SetLayeredWindowAttributes(IntPtr hwnd, uint crKey, byte bAlpha, uint dwFlags);\n"
	source += "}\n"
	csharpProvider = dotnetobject "Microsoft.CSharp.CSharpCodeProvider"
	compilerParams = dotnetobject "System.CodeDom.Compiler.CompilerParameters"
	compilerParams.GenerateInMemory = on
	compilerResults = csharpProvider.CompileAssemblyFromSource compilerParams #(source)
	assembly = compilerResults.CompiledAssembly
	assembly.CreateInstance "Wind32Assists"
global Wind32Ass = CreateUser32AssistAssembly()
fn setWindowSemitransparent hwnd alpha =
	WS_EX_LAYERED           = 0x00080000
	GWL_EXSTYLE         	= (-20)
	LWA_ALPHA               = 0x00000002
	style = Wind32Ass.GetWindowLong hwnd GWL_EXSTYLE
	Wind32Ass.SetWindowLong hwnd GWL_EXSTYLE (bit.or style WS_EX_LAYERED)
	Wind32Ass.SetLayeredWindowAttributes hwnd 0 (alpha*255) LWA_ALPHA
fn setWindowOpaque hwnd =
	GWL_EXSTYLE         	= (-20)
	Wind32Ass.SetLayeredWindowAttributes hwnd 0 255 LWA_ALPHA
	Wind32Ass.SetWindowLong hwnd GWL_EXSTYLE (bit.and style (bit.not WS_EX_LAYERED))
	Wind32Ass.UpdateWindow hwnd
fn findTrackViewHwnd pattern:"*" =
	hwnd = for k=1 to trackView.numTrackViews() do
		name = trackView.getTrackViewName k
		if matchpattern name pattern:pattern do
			hwnd = (trackviews.getTrackView k).ui.hwnd
			exit with hwnd
	if hwnd == OK then 0 else hwnd
------- USING ---------------->
my_trackview_name = "Track View*" -- name or wildcard
hwnd = findTrackViewHwnd pattern:my_trackview_name
setWindowSemitransparent hwnd 0.5 	-- set half-transparent (aplha == 0.5)
setWindowOpaque hwnd 				-- set opaque (aplha == 1)
yun7928903
wow~nice.it's much faster when work with the callback.TKS
-- 实时透明化
fn trackviewAlpha_yun =
( setWindowSemitransparent hwnd 0.5 )
try(unRegisterRedrawViewsCallback trackviewAlpha_yun)catch()
registerRedrawViewsCallback trackviewAlpha_yun
animator
