The Configure Direct3D option setting is initialized.
mercury296
mercury296
The Texture Size option continues to initialize in the Configure Direct3D option.
I am very uncomfortable because this option is reset whenever 3ds max is struck.
The option I want is this picture.
But this is how it is initialized every time you run 3ds max.
Let me know if you know how to solve this problem.
* As I am not good at English, I leave this question through translation program.
ads_royje
Hi @mercury296,
the setting file is at the root of Max install : d3dgfx.ini
When installed in Program Files, default install path, the file cannot be overwritten (Windows rules).
To be able to save the settings:
Either start Max as Administrator (Should have the Write permission to the file) edit setting, exit Max. >>> saved
Or copy the d3dgfx file outside Program Files, modify it in a text editor. Copy back into Program Files. (still need Admin permission).
I hope this can help,
