Struct: call member function from another member function for same instance
I need to call one member function from another inside struct, but it dosen't work just like that. When i try to call another function it says it's "undefined".
I did few google searches and found this forum: http://forums.cgsociety.org/archive/index.php/t-272425.html
On that forum same problem was addressed and resolved with this snippet:
struct objectStruct
--Function Definitions, those two are the magic lines 🙂
Function1=fn Function1(), --define functions
Function2=fn Function2(),
--locals
--Functions
fn Functions1=
Function2()--this would not work if they were not defined as empty above
fn Function2=
--function2 stuff.
Looks like all i needed were function definitions in the top of a struct. Well, sounds right...
But it didn't work for me!! MaxScript parsed these definitions as they were struct functions and therefore spited out
syntax errors about missing "=" signs :)). It looks like it doesn't even know about function definitions :(.
Maxscript documentation doesn't say about function definitions ether, why is that?
So if this solution didn't work how else do i call one function from another inside same instance of a struct?
In a similar context (SimpleObject plugin) I found that an early declaration
local function1
worked.
I could then have a method that called function1,
and finally make the actual function definition. fn
I think this should work for you as well.
Well, i tried it many different ways and couldn't make it work.
If i declare it in such way, at least, it doesn't throw a parsing error now:
struct myStruct
f1 = myStruct.function1(),
fn function1 = ( print "Test" ),
fn function2 = ( f1() )
However when i call function2 it gives me an error "Unknown property: 'f1' "
When i wright something like:
f1 = myStruct.function1() -- Does it assign link to the function, or function's result value?
How did you accomplish early declaration? Can you post some sample code?
Hi, my example was irrelevant as the rules of struct are somewhat different from the rules for plugin class.
However, try the following ...
-- without forward references
struct myStructA
fn f1 = ( print "in f1"; 55 ),
fn f2 = ( print "in f1"; f1()+11 ),
v1 = f2()
rrA = myStructA()
-- with forward references
struct myStructB
fn f1 = (),
fn f2 = (),
v1 = f2(),
rrB = myStructB()
Steve_Curley
This works, without any forward references, locals or anything.
struct Person
Name, Age,
fn GetAge = ( Age ),
fn NameAge = ( Name + " " + (GetAge() as string))
Bill = Person "bill" 45
Bill.NameAge() --> "bill 45"
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Thanks for replies!
Looks like it will work without forward references only if members were declared in order they were used, just like in C++. i didn't know that same rule applies to structs.
s_todd, your example worked for me and it does exactly what i want, thankyou. I don't know why i didn't think of that :).
Now i can make my structs look more like classes!
