access my name, transform etc from script
Aplogies for green question, but I have searched for an answer and can't find it .....
How do I access my name, transform etc from withing a SimpleObject plugin?
I would expect to use this.name and this.transform, but they don't work,
even though this.localVariable or (classOf this) work as I would expect.
It's not easy. I posed the same question a while back and got an answer that works, but it is a bit messy. This was the thread:
area.autodesk.com/forum/Autodesk-3ds-Max/maxscript/getting-the-object-itself-in-a-scripted-plug-in/
Thankyou. Very unsavoury, but ...
Here is an alternative that seems to work and (to me) is not QUITE as bad, still terrible.
Keep a local variable me that refers to my node, and early on in creation make sure I find myself by calling findMe().
This relies on the way the name of a new node is generated.
local me  -- until I find out how to refer to my transform etc properly
function findMe =
if me != undefined then return "" -- in case called twice
me = $myClass01 -- find me, the new one will always be 01
me.name = uniqueName "myClass" -- so next new one is 01 as well
Once I have called findMe() I can use me.transform etc
