struct and Custom atrributes
So I am having a problem, I am trying to create an script that will eventually create a floater that will allow animators to create arbitrary anim ranges and store these ranges as a custom attribute to the rootNode, so this is what I have so far, the problem that i am having is that I want to use a struct instance to store each range as it's been created, then append an array with each struct, so array index x gives us 3 values (name of the range, start frame and end frame) the problem surfaces when I try to define a type for the custom attribute.
some code:
THIS I AM PRELOADING IN STDPLUGS/STDSCRIPTS
struct AnimRangerRange (Rangename, beginframe, endframe)
global defaultAnimRange = AnimRangerRange "Default" 0 100
global bhg_global_anim_ranges_list = #()
append bhg_global_anim_ranges_list defaultAnimRange
then here is my work in progress for the script, (NO FLOATER YET, i AM STILL WORKING OUT THE CUSTOM ATTRIBUTE)
( --begin local scope
animRangerArray = bhg_global_anim_ranges_list
if custAttributes.count rootnode == 0 then --# check to see if any custattributes exist at all, if not, then add the anim ranger attribute and default array.
( -- add attribute and default array
rangerdata = attributes AnimRangerData
parameters main rollout:params
glbanimranges type:#string --# HERE IS THE PROBLEM, HOW DO i SOLVE IT???
) --end params
rollout params "nodata"
) --end pathdata
custAttributes.add rootNode rangerdata #unique
rootNode.AnimRangerData.glbanimranges = animRangerArray
) -- # end no attribute found
else --# of course if custom attributes exist, we need to see if ours is one of them
) --# end else attributes exist
) -- end local scope
Thanks in advance
paulneale
There is no data type that will store a struct. What you can do is have three parameters that each
hold an one of the needed pieces of data. So something like this...
parmeters paramsP
NameArray type:#stringTab tabSize:0 tabSizeVariable:true
StartArray type:#floatTab tabSize:0 tabSizeVariable:true
EndArray type:#floatTab tabSize:0 tabSizeVariable:true
Doesn't look at clean but works just as well.
> some code:
> ) --end params
> ) --end pathdata
> Thanks in advance
Paul Neale
http://paulneale.com
Paul Neale
Lame!!! But your solution is great, I just wanted to parse less arrays, but as long as it works, who cares?
Thanks Paul!
MB
