Strange scope problem in scripted material plugin
paulneale
Advisor Advisor
paulneale
I have a parameter called selfIllumination, it is defined as a float and has a default value of 100, below in a function I try to set that value and I get an error that selfIllumination is undefined and it can not be set.
Now I can set any of the delegate parameters in this function but not any pb2 params for the scripted plugin. The fn is being called by a registerTimeCallBack but I'm not sure that is having any effect.
Any words of wisdom from any one?
Paul Neale
http://paulneale.com
Paul Neale
Nope, I just thought I remembered you saying you gave up on scripted modifiers some time ago...
sorry, but if you figure it out I'd like to know, sounds a bit like a problem I had/have...
-Johan
paulneale
I only found work arounds really. What it had to do with is the on set val handler in the parameter block. I moved it out to the rollout and it works fine. I use scritped modifiers all the time but not for manipulating geometry. I use them for character control panels mostly. And of course tools like PEN Attribute Holder.
Paul Neale
Paul Neale
Ok, I did understand wrong then 🙂
Thanks for posting back, even though unfortunately it's not related to my problem...
-Johan
