Sript about select edges by orientation and top or bottom faces
Message 1 of 1
I have to modeling over 6000 bricks. It is so confusing to draw all of them manually.
I record script which I present below
macroScript Macro2
category:"DragAndDrop"
toolTip:""
subobjectLevel = 4
actionMan.executeAction 0 "50027"
$.EditablePoly.SetSelection #Face #{45..46}
$.EditablePoly.buttonOp #Inset
subobjectLevel = 2
$.EditablePoly.SetSelection #Edge #{46}
$.EditablePoly.SelectEdgeLoop ()
$.EditablePoly.buttonOp #Chamfer
subobjectLevel = 0
actionMan.executeAction 0 "40471" -- MAX Script: Macro Recorder Toggle
at line
I need select top and bottom polygon ( or only top polygon if it is impossible to select both at once )
and at line
I need select top edge on the border.
So as I realise it isn't possible to use the same chamfer value in each action because of disappearing in code this values.
But maybe I don't know everything and It is so easy to achieve other requirements .
I present pictures in order to understand what I mean
Thanks in advance
Replies (0)
