Connect meshes in maxscript
Message 1 of 8
Is there a way to connect meshes in maxscript using 3ds max 2009?
Using the UI, I would select an object, go to "Compound Objects", Connect, Pick Operands and select the other objects. But how do I do it in maxscript?
I looked at the documentation but I didn't find anything.
Replies (7)
Message 2 of 8
Steve_Curley
The first entry (constructor) in the Maxscript help for Connect clearly states that "Connect compound objects are not constructable by Maxscript".
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 3 of 8
Have you looked at meshop.attach()
Message 4 of 8
Steve_Curley
Attach and Connect are entirely different things. Connect is rather like Bridge (in an Editable Poly) but between 2 separate objects, not elements of the same object.
Max 2016 (SP1/EXT1)
Message 5 of 8
Oh right. Sorry, I'm not at my dev pc.
Message 6 of 8
I have looked at it now and, although it is not the same thing as connect, it's good enough for my purposes. Thanks. Being a Max newbie I wasn't aware of it.
Message 7 of 8
Yes, but sorry, I should have explained what I wanted to do in detail. I am just following a tutorial that required me to manually connect a gazillion of spheres to a plane in order to archive a effect. But attach will also work in this case.
Message 8 of 8
Steve_Curley
No problem - but using the correct terminology is quite important, especially in a product as complex as Max. There are many areas where similar names refer to very different operations and can easily be misconstrued by those responding to posts.
Max 2016 (SP1/EXT1)
