smooth out the scaling of particles
mark_aldred
mark_aldred
I have a bunch of particles and the camera moves towards them and through them. I'm scaling them down depending on the distance to the camera. What I'd like to do is have them scale down more once they come within a certain distance. I can do it, but the transition is abrupt. How would I make the transition from one state to the other smooth? Or, is there a better way I could script a controllable curve? Apologies - I'm not a programmer.
Here's the code and I'll attach the file ..
on ChannelsUsed pCont do
	 pCont.usePosition = true
	 pCont.useScale = true
on Init pCont do
on Proceed pCont do
	count = pCont.NumParticles()
	factor = 10	for i in 1 to count do
		pCont.particleIndex = i
		dist = length(pCont.particlePosition-$Point001.pos)
		if dist > 250 then
		scaleMultiplier = dist/20
		else
		scaleMultiplier = dist/30
		pCont.particleScale = scaleMultiplier
on Release pCont do
mark_aldred
I thought I'd found a way to do it with a curve function, but I can't getting it working properly. I drew a curve on GeoGebra and got the formula for it. Then I inserted the formula into the script. The scaling seems to be much more linear than the curve should make it. I've attached the data and a screenshot of the curve.
Any advice welcome.
