Setting position of Symmetry modifier`s mirror to specified position.
wojciech.selwa
wojciech.selwa
Hi all,
I'm running into a problem when trying to control the mirror gizmo of the Symmetry modifier using MaxScript.
What I want to archeive:
For each instance of a referenced object, I want to:
Place it near a Box object in the scene
Apply a Symmetry modifier
Move the symmetry mirror (gizmo) to a specific world position — center of the associated Box.
So far I managed to succesfully create and align referenced objects to the boxes, apply symmetry correctly but I am struggling to align symmetry mirror to desired position. I was trying to align it with a point helper or to specify if by coordinates, but nothing worked so far. Is it even possible to move mirror/gizmo of symmetry modifier using MAxscript? It is either placing gizmo in random place or not moving it at all.
Just want to add that I`m fairly new to the MaxScript.
Thanks!
A娘
it involve coordinate system conversion , the gizmo use local coordinate system of the modifier , and your box you get the positon in global coordinate system
https://help.autodesk.com/view/MAXDEV/2025/ENU/?guid=GUID-1E2277FE-7854-4404-89A9-9D72C07CDBDB
see the conversion demo from link above
MartinBeh
Here is a free script to do that for you: https://scripts.breidt.net/#gizmoControl
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
wojciech.selwa
Thank you @MartinBeh and @A娘, both gave me the answer I was looking for, problem solved!
