Set the pivot of an object to match the pivot of another object?
wyomingstateflag
wyomingstateflag
Setting the transformation of the pivot point of an object to match the pivot of another object seems like something that should be trivial to do. I know position is as easy as object1.pivot =object2.pivot which I expected to get and set the pivot transformation but sadly only handles position.
dmitriy.shpilevoy
Depends on what you are trying to do.
Do you want to align obj1 by obj2 position and rotation or only align its pivot, leaving mesh as it was?
If former - use
object1.transform = object2.transform
A娘
you mean you want to set A's point overlaps B's point , then this was 3D math , you should calculate new transform offset of A
fn AlignPivotA2B A B =
	newtransformoffset = A.objecttransform * inverse B.transform
	A.objectOffsetRot = newtransformoffset.rotationpart
	A.objectOffsetPos = newtransformoffset.translationpart
	A.objectOffsetScale = newtransformoffset.scalepart
	A.transform = B.transform
call the function , and A will be set pivot align to B
wyomingstateflag
Perfect, thanks so much!
